Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
LS1 Heads GP
Old Jul 18, 2004 | 06:18 AM
Demon SS's Avatar
LS1 Heads GP
We are having a GP for LS1 cylinder heads that will run until 7-31-04. We would like to get 5 sets for the GP to go through. Here is the break down
Stage 1 5.7L Heads -$1295.00 shipped(no core)
includes
Hot tanked and pressure tested
Stage 1 ported(CnC'd and hand finished)
Cleaned up combustion chambers
Patriot 2.02 intake valves
Patriot 1.57 exhaust valves
Patriot Dual spring kit
Bronze guides
Viton seals
GM locks
GM seats
FFHP 3 angle valve job
Milled up to .040
Flowed with sheet
Stage 2 5.7L Heads -$1495.00 shipped(no core)
includes
Fully Stage 2 ported(CnC'd and hand finished)
Polished combustion chambers
Patriot 2.055 intake valves
Patriot 1.60 exhaust valves
Patriot Dual spring kit(springs good to .650 lift)
Bronze guides
Milled up to .040
Flowed with sheet
Stage 2 5.3L Heads -$1495.00 shipped(no core)
includes
Bronze guides
Milled if desired
Flowed with sheet
Stage 3 (big bore) Heads $1745.00shipped(no core)
includes
Fully Stage 3 ported(CnC'd and hand finished)
Patriot 2.08 intake valves
Bronze guides
Milled up to .040
Flowed with sheet
For 6.0L heads add $100.00
also in stock we have 1 set of LS6 243 casting heads add $600.00(first come first serve)
Comp Cams cams add $350.00
Custom cams $399.00
Super custom cams -call
GM MLS head gaskets/bolt kit $75.00
If the above packages don't suit your needs/goals give us a call we have many options.
2-4 week lead time after GP ends.
Our CNC work is done by T.E.A.
rideordie
Nov 5, 2019 04:52 PM
Mar 15, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
