Home made headers?
Old Jul 12, 2004 | 11:57 AM
383Z4ME's Avatar
Home made headers?
Last year on 12-15 I started to convert my street car to a dedicated drag car. The only concessions I've made are using the Comp Cams Endure-X solid lifters and street gears for the Strange 12 bolt. I am finally to the point of starting the engine. I had decided to run the Hooker shorties this summer to wring out the suspension and get used to the additional HP. This winter I planned to finish a direct port nitrous setup and install a long tube exhaust. The engine builder pointed out how much of the stock exhaust port was covered by the shorties. The AFR 210's are presumably much worse. I would prefer not to have to resort to trial and error to get a header that was not covering the exhaust port. My theory for maximizing the LT1 engine for drag racing is to run a big shot of nitrous and a long duration, high lift cam. I spent little on porting the intake ports for flow and have spectacular numbers on the exhaust side. I would hate to waste that good result. Can anyone recommend the best header solution for a dedicated race car?
Thanks,
Rick
Old Jul 12, 2004 | 02:55 PM
Stephen 87 IROC's Avatar
They're not going to be cheap.
www.headersbyed.com
www.lemonsheaders.com
Old Jul 15, 2004 | 01:25 AM
RedHottG2's Avatar
www.headersbyed.com
I didnt see on tho's sites where it said they were available for the 93-97. The lemon headers have 93-97 listed but with no info. Does that mean they are only available as a custom order ? Also do you happen to know if these headers have bigger primaries than the Jet Hots and Hooker's ? Thanks for the help man!!
Old Jul 15, 2004 | 07:42 AM
E-mail them and ask.
Old Jul 15, 2004 | 08:58 AM
MrDude_1's Avatar
as far as i know, all of lemons headers are custom.. its what they do.
Old Jul 15, 2004 | 03:55 PM
Mindgame's Avatar
Search Advanced and LT1 Tech for Dynatech headers... I believe some guys were using their 1-7/8" headers with a little modification.
-Mindgame
meissen
Jun 1, 2015 07:59 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Joes96z
Dec 13, 2014 07:48 PM
Joshs99BlackBeauty
Jul 27, 2002 04:22 PM
