replaced fuel pump. now whats wrong?
Old Jun 21, 2004 | 10:45 PM
RED82TA5.7L's Avatar
this on the 82 with TPI
replaced the pump.. and its running. im getting 45 psi at the rail with key on but engine off... when i go to start the car it drops to below 30 psi and car runs for maybe 2-3 seconds then dies.... is there maybe air in the line? maybe i have a kinked line?
ive been trying to get it to stay running for maybe 15 mins and it still trys to run then dies... i dont know what else to do
when i have the key on but engine off i hear gurgling at the fuel rail.. you think maybe my fuel pressure regulator went out? CAN they go out? lol
i just wanna go throw the car off a cliff
Old Jun 21, 2004 | 11:33 PM
doug791's Avatar
Re: replaced fuel pump. now whats wrong?
If mines not up and running by the end of june thats where mines going. Trust me dude i feel your pain, and maybe then some. Not going to be of any help on this one though sorry
Old Jun 23, 2004 | 11:15 AM
transxtreme's Avatar
Clogged fuel filter, clogged rail, bad FPR. Get an adjustable and see wat happens
Old Jun 24, 2004 | 08:10 AM
Lungz's Avatar
I would say this sounds most likely like the FPR going bad as mentioned above, clogged line or filter would probably effect the idle whe in park/neutral as well. I imagine this could potentially be a computer problem of some sort as well. I would also see if it has any codes being thrown and what those codes are, see if you can get your hands on a scan tool and keep it plugged in while you are testing and see what you find out there. Sorry if this has been little help, but those are the directions I would go in.
cmyname1
Feb 19, 2015 08:38 PM
Alex Barnes
Jan 24, 2015 10:21 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
