What is the weight of a stock 67 Camaro?
Old Sep 23, 2002 | 12:56 PM
1967AND2002's Avatar
V8 and 4spd. It seems like I remember 3100.
Old Oct 20, 2002 | 02:53 PM
Dr.Mudge's Avatar
Closer to 3680 from what I've found, 3100? I think your thinking of a stripped and lightened car.
Old Oct 23, 2002 | 06:27 PM
406Camaro's Avatar
First 68 I had only weighed 3120, without a driver. That was with a small block and automatic. Still had stock everything to the best of my knowledge.
Old Oct 24, 2002 | 02:57 AM
Dr.Mudge's Avatar
Crazy, I know they can be made that light, but have not seen numbers that low for stock.
Old Oct 27, 2002 | 02:26 AM
1979Z28's Avatar
Isn't there some sort of a sticker on the driver's side door that shows that?
Old Oct 28, 2002 | 11:09 AM
texlurch's Avatar
My 68 Z with a SBC and 4 speed weighed 3250; that was with headers and aluminum intake, all steel body, full interior, etc, etc
Add another 50 or so for A/C
most 67-69 come in around 3300, the 2nd gens were a little heavier, and in 76 got a LOT heavier, like 3600 - 3750 with A/C
now, if you do some weight removal... my 68 I have now weighs 3010 w/driver, SBC (LT1 Aluminum heads, FI motor)
Old Nov 2, 2002 | 02:44 AM
Dr.Mudge's Avatar
Not sure they had that back then, even with my 69 the ProtectoPlates and VIN etc all told different stories as far as giving info on the car, and there wasn't much info there to find out.
I don't remember anything on the door at all, in fact I remember that being an issue at the DMV when I tried to register the car, and I was like LADY its a 1969 car, things were alot different back then. Working at DMV you'd think they knew those things.
Old Nov 2, 2002 | 06:39 PM
texlurch's Avatar
Even if there is a door sticker, it normally list's the GVWR, Gross vehicle weight rating; which is the car weight, PLUS the amount of weight (people + luggage) that it is rated to carry.
Old Nov 3, 2002 | 07:56 PM
chicane67's Avatar
As posted by Car and Driver, March of 1967:
Curb Weight of said 1967 Z28 was equal to 3250 lbs.
Test weight was equal to 3550 lbs.
http://www.1967z28.com/articles/cc-4.html
Good spec sheet~
My '67 weights in at about 2850, after a ten year diet.
oldschool
Feb 9, 2016 09:21 PM
deadmanrunning
Jan 3, 2015 01:12 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
bossco
Nov 29, 2014 10:18 AM
