Have 12# pulley but only seeing 7-8#
Old Jun 10, 2004 | 06:25 AM
BAD 97 WS-6's Avatar
I have a hotcam and Ported exhaust ports on my LT4 heads. Is there something to look for? Thats a lot of HP missing.
Old Jun 10, 2004 | 08:03 AM
95 Silver TA's Avatar
Re: Have 12# pulley but only seeing 7-8#
Did you check your belt to see if its on snug?
Either way That kinda sounds right to me.
I have a cc305 cam, long tube headers, a low comp 383, STOCK heads....And I am running a 15# pulley (for a stock motor) and I only see 10psi of boost at 5800rpms.
Thx,
Claude
Old Jun 10, 2004 | 08:13 AM
I hear what you are saying.
Last year I had the 8# pulley with untouched heads and smaller head gasket and saw 6#
This year I had the exhaust ports done, along with the chambers to open up the CC's, along with a stock thickness gasket. IS porting where all my boost went?
Old Jun 10, 2004 | 09:24 AM
IDOXLR8's Avatar
The following will attribute to lost in boost:
-Belt Slippage
-Ported heads
-Increasing Bore in block
-Bigger exhaust port headers
-Inefficient intercooler
-vaccumm leak
Old Jun 10, 2004 | 09:56 AM
LT4ultraZ's Avatar
altitude has a lot to do with it to: in sacramento only 25 feet abouve sea leval, my car makes 17lbs in las vegas 2200 feet i see 15lbs and in albuquerque 5600 feet i only see 11lbs.
AviatorDave
Dec 19, 2016 06:35 PM
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Sparkz28
Jul 29, 2002 09:20 PM
