Tuning idle with CC306
Old Jun 9, 2004 | 06:51 AM
Viking's Avatar
Time to tune in my new engine
415cui
9.0:1 comp
cc306
Changes so far
Closed Throttle SA 24deg
Idle speed N 1000rpm
Idle speed D 800rpm
Vacuum is 8-10 at 1000rpm
O2 swing points lowered 100mV
But I think the idle still is to rough, what timing doea you CC306 guys have at closed throttle?
/N.
Old Jun 9, 2004 | 02:37 PM
TriPinTaZ's Avatar
i would try to set it to atleast 32 degrees of closed throttle timing.
I personally run 40 degrees at idle but my cams bigger then a cc306
Old Jun 9, 2004 | 11:51 PM
Viking's Avatar
Bumped up the timing to 29 deg last night, vacuum increased to 11 at idle. Will try to increse it some more.
It seems like it likes to ramp up the timing fast from idle and up...
Do you set the lower values in the main SA tabel to the 40 deg to?! Your main SA table would look real fun then........
/N.
Old Jun 10, 2004 | 05:00 PM
TriPinTaZ's Avatar
my timing table below 3500 is anywhere between 41-43 degrees of advance. so at idle its 40 and at throttle tip in it increases slightly which makes the car reponsive and not stumble. but my cam is bigger than a cc306 so you wont need nearly that much timing. But is is a good idea to have a degree or 2 more timing at throttle tip in then at idle. will prevent stumbles
Old Jun 10, 2004 | 11:28 PM
96TurboTA's Avatar
I would love to see either of your closed throttle SA tables. u can email me at baodysseus@aol.com.
thanks,
Josh
Old Jun 11, 2004 | 12:01 AM
Viking's Avatar
So your SA is almost flat in the part throttle driving area- interesting!
/N.
Old Jun 11, 2004 | 10:38 AM
TriPinTaZ's Avatar
/N.
yup, with a cam as large as mine its needed. btw....Joe Overton helped me
Old Jun 12, 2004 | 12:18 AM
Viking's Avatar
I would really love to look at yout table could to make a screenshot of it and email me?
/N.
mightymouse383
Jul 20, 2016 07:34 AM
REDNECKISBOSS
Apr 13, 2015 07:55 AM
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 22, 2015 02:45 PM
JurisAg02
Jul 27, 2002 11:49 AM
