Bypass Valve Location....
Old Jun 4, 2004 | 07:02 AM
IDOXLR8's Avatar
Where do you guys have your aftermarket bypass valve mounted? I am currently running an ATI race bypass valve and have it mounted on my trickflow elbow. I was told that the bypass valve should be between the discharged side of the blower and the intercooler. The way I have mine setup it is after the intercooler. Thanks
Old Jun 4, 2004 | 07:15 AM
1st and goal's Avatar
I have mine after the intercooler.
SD Concepts (who fixed my tensioner problems) also thought I should move my BOV between the discharge tube of the blower and the intercooler, with the thought being that you will not be blowing medium hot air constantly through the intercooler......the other way to look at it is that if you have it before the intercooler the intercooler could get heat soaked (mine is a front mount) and the first blast of power is going to be hotter than it should be.
Just pulled the "way back" machine out and looked at an old picture of my install as detailed by the ATI manual and they have it after the intercooler.
Marc
Old Jun 4, 2004 | 07:19 AM
MEAN LT1's Avatar
Re: Bypass Valve Location....
I dont think theres a problem with your location. Ive seen many bov/bypass valves located on the hard intake elbow. But then again I ve also heard that the ideal location should be closer to the actual blower. i dont think either way is going to hurt you.
Old Jun 4, 2004 | 07:44 AM
IDOXLR8's Avatar
Marc
Thanks.
Old Jun 4, 2004 | 08:13 AM
Acct 23749's Avatar
On my ATi twin flows its right after the blower but before intercoolers
Old Jun 4, 2004 | 08:17 AM
IDOXLR8's Avatar
I an assuming you are still running the stock Bosch bypass valve.
Old Jun 4, 2004 | 09:36 AM
Camaro_SS/R's Avatar
IMO, I think it doesn't really matter.
However, the benefit of installing the bypass valve before an intercooler or aftercooler is that you don't have to waste their effort in cooling the charge and then sending it back to the supercharger where it will just get heated back up. Secondly, I think it will assure that whatever boost that will surge back to damage the SC will get bypass back downstream of the SC.
With this said, the instruction for the Vortech systems has the bypass valve installed after the aftercooler about a foot from the TB. That is where mine is sitting.
I have two pipes, one with the regular bypass valve and another with a HKS SSQ BOV (don't bother with a BOV). They both work well.
Old Jun 4, 2004 | 11:16 AM
Acct 23749's Avatar
Correct. I have been to ungulfed in all the other lil problems to research BOV or bypass valves...
Is the stock one inadiquate or anything?
Old Jun 4, 2004 | 12:36 PM
IDOXLR8's Avatar
I believe the stock bypass valve is more than adequate for your setup.
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
