amp not on, urgent
Old May 29, 2004 | 10:26 PM
raiderman119's Avatar
Exclamation amp not on, urgent
I am wiring my new HU and i get done, and i can hear the sound, barely, with the volume all the way up. I think that my amp is not turning on (factory amp). How do I fix this?. i bought the sochee adaptor to run the amp. . which wire is the remote line going into the amp? and what one will make my antenna go up.
Old May 30, 2004 | 08:06 AM
LS1 RULZ's Avatar
Why are you using an adapter to connect a factory HU to a factory amp?
The factory amp doesn't use a remote turn-on lead. It senses when there is an input voltage coming from the HU and turns on.
Old May 30, 2004 | 09:24 AM
sorry, it is a jvc Hu, not the factory one. i re checked the wiring and there is no sound at all now. the amp is cold, so i know that it is not on. I need to know how to get it on.
Old May 30, 2004 | 10:36 AM
LS1 RULZ's Avatar
This is the best adapter for adding an after-market HU to the factory stereo in a '99 Firebird.
PAC OEM-1
It plugs directly into the factory harness so you don't have to cut and splice any of the factory wiring. You'll also need the ADD-GM21C cable harness to go with the OEM-1
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
NewsBot
Jan 8, 2015 11:29 PM
MJ_Z28
Aug 7, 2002 07:15 PM
