Flywheel resurfacing?
Old May 28, 2004 | 01:58 PM
coogsLS1's Avatar
Question Flywheel resurfacing?
When I am installing my new clutch set, is it a must to get the flywheel resurfaced?
If so, how much does this normally run? What kinda shops can do it or can I do it myself?
Old May 28, 2004 | 04:49 PM
stingant0's Avatar
don't listen to anyone that tells you not too. It is a must. Most clutch companies will void their warrenty if it is not machined. I got mine done at CarQuest for $30. However, not all CarQuests have a machine shop. Just call around. It only takes an hour for them to do it.
jon
Old May 28, 2004 | 05:40 PM
coogsLS1's Avatar
30 bucks isnt bad. whats involved in the process?
Old May 28, 2004 | 06:09 PM
Dave89IROC's Avatar
Pep Boys should be able to do it also
Old May 28, 2004 | 07:58 PM
OBE1 95Z28's Avatar
Very similar process to turning your brake rotors...definitely get the flywheel resurfaced.
Old May 28, 2004 | 08:26 PM
HBHRacing's Avatar
I ahve also heard that the flywheel must be shimed in the amount of material removed. I have not found any back up info on this but it does make scence. anyone have more info or places that will carry shims?
Old May 28, 2004 | 09:57 PM
coogsLS1's Avatar
I havent heard of that. Would you really need to considering that it would be minimal amounts lost and just a natural process for a flywheel?
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
karpetcm
Sep 29, 2015 10:08 AM
Jake Bialke
Sep 24, 2015 11:31 AM
Bxlt1
Sep 17, 2015 08:31 AM
