need tips on fixing my ride
Old May 27, 2004 | 10:47 AM
min9861's Avatar
i have a 93 z28a4 and im trying to figure out what parts i should get. im trying to reach 13 flat or so for 1/4. no nitrous please. thanks alot
Old May 27, 2004 | 12:49 PM
Schearer225's Avatar
I would say the follwing things would get you to a 13 flat
1. Cat-back exhaust
2. Cold Air Intake
3. Headers
4. 3,000 RPM tourque Converter
5. Transgo shift Kit
6. Radials/Slicks
7. Programmed PCM
8. Weight reduction, take out all you don't need
THIS SHOULD GET YOU PRETTY CLOSE TO THE TIME YOU ARE LOOKING FOR.... BUT IF YOU WNAT A LITTLE MROE KICK, THEN GET A KILLER CAM SETUP
HOPE THIS HELPS
Old May 27, 2004 | 01:32 PM
teke184's Avatar
i would also look into some lower control arms and maybe relocation brackets to get a good launch.
other things to look into would be and electric water and gears
Old May 27, 2004 | 05:53 PM
Loony's Avatar
Slash the cat-back, get a cut out...its cheaper, yea...unless you want a cat back. Just my advice
Old May 27, 2004 | 10:56 PM
min9861's Avatar
ok whats a cut out?
Old May 27, 2004 | 11:20 PM
Poik's Avatar
www.dmhperformance.com make electronic cutouts. Go there, you will get the idea.
TheGreenZ28
Oct 4, 2020 11:29 AM
May 15, 2015 10:43 AM
timmy39120
May 2, 2015 05:12 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
MislMan
Jul 19, 2002 11:41 AM
