Dropping air pressure
Old May 21, 2004 | 01:05 PM
1msfyter's Avatar
On street tires. How much can I remove to drag race? I have 275/40/18 on the rear goodyear F1 runflats. I want to improve my traction.Sorry I sold my drag radials. I also have my fron swaybar disconected.
Old May 21, 2004 | 08:13 PM
Stephen 87 IROC's Avatar
Most street tires don't like going below 28 psi. Once they get below that the sidewalls are too stiff to roll over and it forces the center of the tire off the ground which gives you even less traction.
Many times a street radial tire will hook up better with more air pressure not less.
Old May 21, 2004 | 09:25 PM
Capn Pete's Avatar
Agreed. I tried dropping my tire pressure as low as 20 - 22 psi last year w/ 3.73's, and my 60' times didn't improve at all.....in fact, I think they got worse? (like 2.3's?! ). On the street, I was noticing a lot more wheel spin and chirping, so I inflated the tires from 30 to 35 psi, and I was getting better traction after? I think I should have tried that at the track too.
Old May 22, 2004 | 04:44 PM
Loony's Avatar
I used to run my 245's around 28...worked best for me
Old May 24, 2004 | 02:16 AM
HungryT/A's Avatar
35 psi worked for me best, too. Anything below that, and I was getting no traction at all...
Old May 24, 2004 | 03:01 PM
LT1Squirrel's Avatar
just run them at the minimum recomended
Old May 28, 2004 | 07:34 PM
OBE1 95Z28's Avatar
The other thing is to increase the pressure in your front tires to reduce rolling resistance. I usually bump my fronts up to 40 psi at the track.
HectorM52
Jul 30, 2017 11:46 AM
Dec 1, 2016 05:37 PM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
jp2002ls1
Jul 22, 2002 04:18 PM
