LS1 Aluminum driveshaft ET/HP limits
Old May 18, 2004 | 01:30 PM
FASTFATBOY's Avatar
Will the factory LS1 shaft run mid 10's in a 3700 lb 500RWHP, 4L60E equipped 94 Z28 and live, or do I need to drop the dough for a good shaft?
David
Old May 18, 2004 | 03:55 PM
GREGG 97Z's Avatar
I've seen and heard of people breaking them with 300rwhp or less, mainly M6 cars though. The LS1 ds isnt made for drag racing, they're not all that strong. In an M6 car with that hp it would probably go quick, in an A4 it might hold for a while but thats still a lot of rwhp and and a rather heavy car. I would go with something stronger.
Old May 18, 2004 | 07:56 PM
Stephen 87 IROC's Avatar
The factory aluminum driveshaft is very weak. It's a thin walled tube with a cardboard insert.
If you have a lot of HP, either buy an aftermarket aluminum shaft or a good steel shaft. I use a custom made 3" diameter x .083" walled steel shaft in my race car with 1350 series u-joints. A local driveline shop made it up for me.
Old May 19, 2004 | 12:00 AM
Joe Brodman's Avatar
GP Moderator
This man is right on the money. I found out the hard way; twisted my LS1 shaft apart right in the middle on launch.....I don't think my car moved 2 inches. Thank god I have a DS loop.
Replaced it w/ a Spohn 3" steel DS. Very heavy DS, but is solid, well built, and well balanced. Might hurt me a bit in power to the ground and weight, but one less thing I have to worry about breaking.
Old May 19, 2004 | 12:03 AM
Knowklew's Avatar
I guess you just have to choose your breaking point.........engine, tranny, driveshaft, or rear end
Old May 19, 2004 | 03:15 AM
LSs1Power's Avatar
Do ur self a favor and change the stock DS. This is what happend to mine on a 5500RPM launch on Nittos.
http://www.msnusers.com/CarsRelatedG...oto&PhotoID=12
http://www.msnusers.com/CarsRelatedG...oto&PhotoID=13
http://www.msnusers.com/CarsRelatedG...oto&PhotoID=14
http://www.msnusers.com/CarsRelatedG...oto&PhotoID=15
Old May 19, 2004 | 07:08 AM
FASTFATBOY's Avatar
All you guys that have broken them have manual tranny, or a trans brake. I know of guys here locally that have went high 10's on the aluminum shaft with an auto and a footbrake as I will have do you guys know of anyone in the 10's with an automatic and the aluminum shaft??
David
Old May 19, 2004 | 08:29 AM
TedH's Avatar
I have a LPE driveshaft. Reasonable price and have not had any problems.
Old May 28, 2004 | 07:50 PM
OBE1 95Z28's Avatar
Another vote for the LPE shaft. It's 3.5" diameter and much thicker walled that the LS1 shaft. The yoke area is also beefed up. The 3" steel shaft would certainly be more durable, but it costs you in rotation mass.
Old May 29, 2004 | 08:20 AM
DarkHorse's Avatar
Didn't you answer your own question?
Will it run 10's auto 500hp
then
I know guys that have done it
Old May 29, 2004 | 09:15 AM
rskrause's Avatar
If you must have an Al driveshaft the Lingenfelter 3.5" shaft or Denny's HD shaft are good bets. But I would get a good steel shaft for drag racing. Denny's or Dynotech are two good sources.
Rich Krause
Old May 29, 2004 | 09:20 AM
FASTFATBOY's Avatar
I may have found us a good source for shafts
www.musclemotorsports.com
$50 a shot
David
Old Jun 1, 2004 | 04:26 AM
rskrause's Avatar
Originally posted by FLYNLOW92rs
What about a carbon fiber driveshaft, would that be even better then the steel/aluminum or is it asking for trouble with high HP numbers.....
CF has some theoretical advantages for a DS. But they are expensive and I have heard bad things about the available units. Not something I would try.
Rich Krause
Old Jun 1, 2004 | 07:49 AM
T/A lt1's Avatar
well I put my stock LS1 aluminum driveshaft thru some hell this weekend and it held up. 5 10sec. passes but the car never dead hooked on any of the passes and my best 60' was 1.60 so with a dead hook the shaft might twist up but it may not.
Old Jun 1, 2004 | 01:00 PM
MEATHEAD's Avatar
Hey David, why don't you get clutch products to build you one. That's what Tommy is running and he is running well over 1000 hp at 3200 LBS, no failures yet.
Shannon
