will these tires fit my Z?....
Old May 17, 2004 | 05:08 PM
jeff2004's Avatar
My brother has some tires/wheels that he had on his old mustang, but i think they might be too small to fit on my z. The tires say 275/60b/14...i think. so that means that they are on 14" rims, right? I'm not exactly sure what each number on tires mean. I know the first one is the width, but i dunno what it is measured in. And the last number is the rim size, Right? What is the middle number...and what is the letter for??
Jeff
Old May 17, 2004 | 05:09 PM
Eric H's Avatar
Correct, they are for a 14" wheel.
-Eric H
Old May 17, 2004 | 05:11 PM
jeff2004's Avatar
Ok, so will my car look funny with 14" rims? They seem kind of small. and what are the other numbers and letter for???
Jeff
notstock4long's Avatar
The first number I believe measures from bead to bead, basically the tread part, and it is in millimeters. The second number is the sidewall height, foir instance, truck tires will have a higher number here than the little rubberbands on 22" wheels. The letter is the speed rating, I think Z is the best. The last number is the diameter of the wheel in inches.
Old May 17, 2004 | 05:12 PM
Eric H's Avatar
The first number is the width of the tire. The second is the height.
Honestly, I think your car wouldn't look good with a 14" wheel. But I doubt they would bolt on anyway. They probably have a different bolt pattern and backspacing.
-Eric H
Old May 17, 2004 | 05:15 PM
jeff2004's Avatar
Ok, thanx for the replies guys. I was jus wondering if they would fit, because if i ever went to the track, these are nice wide tires, and i think they might be DR's too, not exactly sure though. I think you might be right about the backspacing, they seemed really deep. Our cars have a 5 bolt pattern right?
Jeff
Old May 18, 2004 | 03:11 PM
lol, well yeah, there are 5 bolts, but it is a 5 X4.75" bolt pattern. Get some pics, I have never seen 14's on an fbody
Old May 18, 2004 | 03:16 PM
stangitr's Avatar
i think it would look hilarious
Old May 18, 2004 | 09:35 PM
ImportedRoomate's Avatar
-Eric H
Ill elaborate just a bit. The second number isnt a set measurement, but a percentage of the width of the tire. Therefore, for example, a 275/60 tire is gonna have a (275mm*60%)=165mm sidewall height.
Also, if that size tire you gave was accurate, that makes for a 27" diameter tire which is a little over an inch bigger than standard camaro tires. So your speedometer and odometer will be a little off.
Old May 18, 2004 | 11:02 PM
I seriously doubt you could fit a 14" wheel on a 4th Gen.... many of us using 15" wheels for slicks have to resort to grinding down the calipers (rear) and adding spacers (front).
Old May 19, 2004 | 02:26 PM
Is this true Injuneer? That the sidewall is a percentage of the width? No offense IR, but I have never heard anything like that before...
Old May 19, 2004 | 09:04 PM
Check near the bottom for aspect ratio
I like tirerack's better, its closer to what I said.
Old May 20, 2004 | 12:13 AM
Yes.... that is 100% correct. A "40" aspect ratio tire has a sidewall height that is 40% of the widest part of the tire (section width).
For a 275/40-17
275 = section width, or widest part of the tire = 275mm / 25.4 = 10.83" section width.
Sidewall = 40% of section width = 0.40 X 10.83" = 4.33"
Diameter of the tire = wheel diameter + 2 sidewalls = 17 + (2 X 4.33) = 17 + 8.66 = 25.66" diameter
Old May 21, 2004 | 10:56 AM
Thanks guys! I have never made the connection before, although I have heard of 'aspect ratio', just never really though about it. So a 315 with a 40 sidewall would be higher than a 245 with a 40 sidewall, right?
Old May 21, 2004 | 11:28 AM
Yes:
315 / 25.4 = 12.40"
0.40 X 12.40 = 4.96"
245 / 25.4 = 9.65"
0.40 X 9.65 = 3.86"
mschmidt33
Mar 15, 2015 07:20 PM
cristian1311
Mar 4, 2015 04:45 PM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
Jim S. '95 Z28
Jul 19, 2002 09:47 AM
