problems...
Old May 15, 2004 | 11:31 PM
Mr.Smith's Avatar
Question problems...
Sometimes, when i put my foot to the floor, my car decides it doesn't wanna excelerate(sp?) . It'll usually pull of the line, and then when it a certain point... it's usually been around 3, but varys... it doesn't accelerate anymore, sometimes on shifts it does the same thing. Had it do it on my while taking a turn after a stop... full gas, and going nowhere... please help
I thought it might be the tranny going, but i thought that if it was slipping that the RPMs would be going up, and not the speed... but neither goes up.
86 Z-28... wit the 350 if that matters
Old May 15, 2004 | 11:38 PM
90rocz's Avatar
Is it down-shifting like it should, cause if it don't it'll bog down and not accelerate...more info??
Old May 15, 2004 | 11:45 PM
Mr.Smith's Avatar
as far as i can tell its downshifting properly. Like i said, it starts fine (usually) its just when it gets to around 3000 rpms that it bogs down and doesn't accelerate. idk, you'd really have to be there when it happens to see what happens. Any tests i can run through.. on the road or otherwise, to check for common problems? what might i listen for, or pay attention to next time i drive?
Old May 15, 2004 | 11:48 PM
97WS6SCharged's Avatar
Have you tried doing a simple tune up? Plugs, wires, cap and rotor, fuel filter, adjust the carb if equipped and set the timing. Also, if you are using a carb, you might look into having it rebuilt if it's been on the car a while.
Old May 15, 2004 | 11:52 PM
Mr.Smith's Avatar
ya, i was planning on having a tune-up done next week, since my knowledge of engine borders on nothing... and my friend meantioned that they sell high-flow carbs? idk if thats true, or if it's even worth it...
Old May 16, 2004 | 12:01 AM
90rocz's Avatar
So you do have a carb then?
Old May 16, 2004 | 05:58 AM
greezemonkey's Avatar
Sounds like a fuel delivery problem.
Old May 16, 2004 | 06:15 AM
aklim's Avatar
Have to check fuel pressure also. Change fuel filter too.
Old May 16, 2004 | 07:34 AM
Mr.Smith's Avatar
ya i do have a carb...
Old May 16, 2004 | 08:00 AM
Mr.Smith's Avatar
and thanks guys, i'll have those things checked out to see what the deal is...
MustangEater82
Dec 30, 2005 07:40 AM
Highlander
Sep 15, 2004 08:42 PM
MustangEater82
Sep 30, 2003 12:09 AM
frmula1
Apr 30, 2003 02:07 PM
