Lou's Short Stick Shifter
Old May 7, 2004 | 03:43 PM
Xride's Avatar
All I have to say is.... is it jsut me or is getting it into reverse a fricken fight???
I have a hurst shifter and jsut put the short stick on, and DAMN am I that weak? or do others fint it hard to get it into reverse with the shorter stick?
Old May 7, 2004 | 03:46 PM
MrDude_1's Avatar
if it takes any extra effort at all to go into reverse, your lockout is not cutting off properly.
you may have to put it in 1st, then shift to reverse, but if you're talking about it being difficult to pass thru the gate past the 5-6 mark, then you need to check your lockout.
the one up top, directly next to the shifter is the reverse lockout connection.
make sure its tight, and then if it still doesnt work, check it for power.
Old May 8, 2004 | 07:40 PM
Mike94ZLT1's Avatar
Mines a little harder than it was with the regular handle and the B&M. I dont back up all that much so I dont care, its worth it!
slocody
Feb 10, 2003 01:04 PM
GRN96WS6
Sep 8, 2002 10:45 PM
slothgrant
Aug 22, 2002 03:01 PM
jim88iroc305
Aug 13, 2002 09:24 PM
kurob25
Aug 5, 2002 08:03 PM
