Problem with rear braking again.
Old May 5, 2004 | 06:02 PM
Cerwin Vega Fan's Avatar
Unhappy Problem with rear braking again.
Ok when I apply my brakes I hear a light squeak noise that comes form the rear of my car. If light to mid pressure is applied I hear the squeak like sound (it is a constant tone too) but when I really push hard one the brakes the sound disappears. I'm not a 100% sure what side is it coming from though. I know it is coming from the rear of the car but not sure which side. I'm kinda leaning towards the drivers side but it is kind of unfair to judge that since most of the time only my driver's side window is down. The reason I think the problem is on the other side is cause that is the side that I hit a fence with. The damage done to the car (besides the big dent and damaged rim) was a warped rotor, bent axle, and the little e-brake thing was jammed. I'm thinking maybe the was caliper might have been damaged too. How would I go about checking to see what is wrong?
Thanks,
Chris
Old May 5, 2004 | 06:09 PM
Bone Daddy's Avatar
I know you replaced all the damaged parts right? Squeek's (like that) are usually a roter that needs to be turned or is warped.
Old May 5, 2004 | 06:27 PM
I changed the rotor onthe drivers side, if I'm going to change the other then I might as well just change all 4 to power slot rotors
Old May 5, 2004 | 09:05 PM
CamaroSS30thAnn's Avatar
minds well
Old May 5, 2004 | 10:23 PM
Hey guys I was talking to someone and I was told it could be a bent caliper bracket. If the axle bent and the disc went with it, so I might have a bent caliper bracket.
Old May 5, 2004 | 10:31 PM
Bone Daddy's Avatar
Eh... that bracket is almost an inch thick, even thicker at the mounting points. It would've snapped one of the bolts or bent the axle flange first. Not to mention you would have had to bang the [-]ell out of that side to do that. In other words you would have been towed home. Your friend is hitting the becardi a bit too much.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
bossco
Nov 29, 2014 10:18 AM
