XX-trim Project
Old Apr 27, 2004 | 09:25 AM
stealth2's Avatar
XX-trim Project
Well, I've decided to abandon my YSI and build a new LS1 setup based around a Vortech XX-trim, which means new:
fuel pump
fuel rails
injectors
aftercooler
EMU
heads
cam
valve train
It's only money.
Old Apr 27, 2004 | 09:44 AM
IDOXLR8's Avatar
Re: XX-trim Project
fuel pump
fuel rails
injectors
aftercooler
EMU
heads
cam
valve train
It's only money.
Good luck. Must be nice to have money.
Old Apr 27, 2004 | 09:50 AM
stealth2's Avatar
I'll borrow it.
Old Apr 27, 2004 | 01:41 PM
bowtiepwr's Avatar
Re: XX-trim Project
fuel pump
fuel rails
injectors
aftercooler
EMU
heads
cam
valve train
It's only money.
>some questions for you ...
- what bracket will you use for the XX-trim ?
- won't the Aftercooler restrict the amount of air from the XX-trim ?
- will there be enough room for a blower that size ?
- and ... will you have to remove the air pump ?
Old Apr 27, 2004 | 01:45 PM
stealth2's Avatar
Custom bracket and aftercooler. It should fit but I will mock it up first. No air pump.
Old Apr 27, 2004 | 05:58 PM
mongse_1's Avatar
What kind of times did you get out of the YS-setup? I've never seen a true LS1 supercharged car run it's *** off yet. I would think a YS-based setup would be pretty damn quick.
Old Apr 27, 2004 | 07:20 PM
stealth2's Avatar
Well, ironically, I have a new YSI blower that has never made a run down the track. I've just decide to change to the XX because the car would not otherwise be as fast as it needs to be.
I've heard there's a couple of Lt/LS cars out there running high 8s on the YS blower.
Old May 3, 2004 | 08:55 AM
mongse_1's Avatar
I can think of one LT1 running that time. All the YS-trim LS1s "should" run that, but could woulda shoulda...you know.
Old May 3, 2004 | 09:24 AM
Highlander's Avatar
Well I just bought a brand new YSi trim for high 9s, I've seen a few YS-trims go 9.00s @158-159 mph on the 1/4 so I assume that the YSi, being more efficient and flowing a bit more it should reach the 8.9s@160mph mark. with 160mph and a good launch one can get into the 8.7s at the same mph.
Old May 3, 2004 | 09:30 AM
got_hp?'s Avatar
Ronnie Duke.....fastest ls1 at the moment.
387ci C5R, F1-R blower, 400 trans, 9", 3.90 gear.........8.52 @163mph.
why just an 8?..........its a 3692lb convertible.
with all the huge ls1 projects ive seen glimpses of, im sure there will be people in the low 8's and high 7's eventually.
Old May 3, 2004 | 09:56 AM
stealth2's Avatar
No LS1 owner has ever been more frustrated with his/her car than I am with mine, and its coulda, mighta, woulda, shoulda, hope-to-a, shouldn't it, why doesn't it crap. A SBC would have been soooOOOO much easier.
Old May 3, 2004 | 06:07 PM
ryan2's Avatar
XX?
all blower this time or will you still be spraying?
Also, Ronnie/Kurt sprayed on that 8.52 pass, but he has run 8's on blower alone.
Stealh, are you going to use an air/water or the same front mount?
you know, you could go SBC and still run Outlaw in the LS1tech stuff. just need to keep the suspension and EFI.
I say go NA and throw a 4-link in....just because
Old May 3, 2004 | 09:34 PM
got_hp?'s Avatar
Re: XX?
yeah, he went 8.62 without the nitrous.......so not really a big difference
Old May 3, 2004 | 09:38 PM
stealth2's Avatar
I'll use a small shot to cool the charge.
Old May 4, 2004 | 07:13 PM
mongse_1's Avatar
C5R...F-1R...that's sledgehammering into the 8s. I'm talking about a production aluminum/iron block, running production heads (LS6/LS1/5.3/6.0), running the number that they should. Not trying to knock anyone, but I'm just not seeing the track numbers matching up with the dyno numbers. I think that will change in '04 though. Meaney's Big Stuff system looks like it's gonna be the hot ticket for blower cars.
