No tubes with ET streets??
Old Sep 18, 2002 | 03:28 PM
jkbadz28's Avatar
Question No tubes with ET streets??
Will this be ok I will be mounting them on some factory wheels. And what psi should I run. The car is a 97Z full weight with Vigi 2800 making about 325 rwhp.
Old Sep 18, 2002 | 03:49 PM
FRDnemesis's Avatar
I dont run tubes in mine either. I hope to be running mine this weekend weather permitting. Maybe some 10's Depends on traction and how brave I feel
Old Sep 18, 2002 | 03:54 PM
jkbadz28's Avatar
Thanks Jeff did you check the other post in the N20 section? Were are you going this weekend the ROCK?
Later Jason
Old Sep 18, 2002 | 04:08 PM
TedH's Avatar
I started running tubes back when I had 320hp becauxse they would spin on the rim. I also went to tubes and rim screws. I have not had a problem since doing this.
What size ET Streets?
Old Sep 18, 2002 | 04:10 PM
jkbadz28's Avatar
26x10.5x16
Jason
Old Sep 18, 2002 | 04:45 PM
FRDnemesis's Avatar
Yep, going to the THE ROCK this weekend. I am leaving Thursday after work to head that way. Wish I had a truck and trailer!!!
You going if it doesnt rain?
Shhhhhhhh pretend I didnt say that
Old Sep 18, 2002 | 07:23 PM
rskrause's Avatar
I dunno, but to me it makes sense to use rim screws and tubes. After all, we're talkin tires inflated to 12psi on a 4000+lb car going >130mph
Seems like cheap "insurance" to me!
Rich Krause
Old Sep 19, 2002 | 08:11 AM
Bob Cosby's Avatar
I used to run tubes and screws with slicks and ET streets, however, I never do anymore. Unless the tires are turning on the rim (which is possible without screws), then I could do without the weight and hassle of tubes.
FWIW...I've never "blown" a slick or ET Street in tubeless form. I have blown a tube at the big end of the track.
Old Sep 19, 2002 | 04:07 PM
Joe Brodman's Avatar
GP Moderator
I run ET Streets, 26x11.5x16 on 16x9.5 Centerlines, no tubes but WITH rim screws.
Yes, they leak slightly, about 1psi a day. Of course, that doesn't mean jack when it comes to drag racing, since you are only running the tires for a few hours.
Old Sep 20, 2002 | 03:30 PM
Derrick Redd's Avatar
I never had a problem running without tubes. Ran 26x10x16 ET Drags and 26x11.5x16 ET Streets.
Old Sep 22, 2002 | 11:57 AM
GJE94Z28's Avatar
Wink
Mine our tubeless, run about 12-15lbs.
HectorM52
Jul 30, 2017 11:46 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
Queens94z28
Nov 20, 2014 06:03 PM
