9.5" width all the way around?
Old Apr 13, 2004 | 05:25 PM
CobraJetG7's Avatar
I'm looking to get a set of zr1 replicas which will be 9.5" width all the way around and I was wondering if they would fit no problem with no additional parts or pieces. and if they would jut out very much. I have a 97 z
Old Apr 13, 2004 | 10:19 PM
XLR-ATE's Avatar
they will fit fine, the wheels i have now were on my old '93 Z28 and fit fine. looked great too.
Old Apr 14, 2004 | 12:30 PM
Just be sure you get the "correct" 56mm offset for the ZR1 17x9.5 replicas. With a 275/40 tire, they will look just like the front wheels in this picture:
http://cjcfo.fbody.com/members/injun...C/Rr34Dr02.jpg
Old Apr 14, 2004 | 03:04 PM
CamaroBoy96Z28's Avatar
My Z06's are 9.5" wide on all 4 corners. No problems at all. Definitely be sure to listen to what Injuneer said to make sure the wheels fit right. 275/40s would be the best to run on the rims too. I went with 265s in front for cost reasons and I wish I had 275s on the front too to protect the lip of the rim.
Old Apr 14, 2004 | 11:51 PM
Clintw1211's Avatar
will the 275/40's on a 17x9.5" rim give you a "straight up/down sidewall, or will it lean in like the rim is to big for the tire? I want to make sure it fits and looks correct!
Anyone know what I mean, how the tire bows out around the bead of the rim like it is to small?
I plan to run the 17x9.5 zr-1's so i just want to make sure!
Old Apr 15, 2004 | 09:16 AM
A 9.5" wide rim has an overall width of slightly less than 10.5" (including the edge flanges). A 275 theoretical section width is 10.83", and the typical 275 will measure 10.8 - 11.0" wide, so its going to fit pretty "square" to the wheel. IMHO that is the best way, doesn't look like a skinny tire on a too wide rim, and doesn't look like a too wide tire on a narrow rim.
The right hand tire is a 275/40-17 Goodyear GS-C on a 17x9.5" wheel, and you can't see the rim.... it is sunk slightly into the edge of the tire, offering a little (but not a lot) protection from curb rash. The tire on the left is a 315/35-17 BFG drag radial on a 17x11 wheel.
http://cjcfo.fbody.com/members/injun...s/315v275a.jpg
Old Apr 17, 2004 | 02:14 AM
Bud M's Avatar
I have 285s on 9.5s, pics in my sig
Old Apr 17, 2004 | 04:51 PM
1stls1's Avatar
I'm about to go w/ black Z06 17/ 9.5 w/ 285/40/17 on all corners. I souldn't have any problems, right!
Old Apr 19, 2004 | 03:02 PM
Coolformula's Avatar
I got 9.5 zr1 with the 285 kumho mx tires with the lip guard i like them. No promelbems
jagsy
May 7, 2003 09:38 AM
Eric H
V6 Tech
Mar 23, 2003 06:33 PM
lt4 fd
Mar 13, 2003 08:57 PM
stonedchihuahua
3rd Gen / L98 Engine Tech
Feb 14, 2003 01:02 AM
Ponyhntr
Advanced Tech
Dec 26, 2002 01:30 PM
