tell me this isnt godo right ????
Old Apr 12, 2004 | 02:41 AM
619SS's Avatar
Unhappy tell me this isnt godo right ????
i have a 98 camaro ss (had it bout a year) kinda high milage pushin 100,000 BUT for some reason everytime it gets to close to redlinin or if i slam on the gas it sounds like a bolt or sumthin is jumpin around in the engine kinda like a clieck click clieck noise? but doesnt do it if im just crusin low rpm's./...... u know what that is or how can i fix it ? thx ne info would help thx.
Old Apr 12, 2004 | 06:22 AM
teke184's Avatar
bent pushrod? maybe one of the roller rockers is falling apart like alot have.
i'd pull the valve cover and check the rockers first
Old Apr 12, 2004 | 07:29 AM
DARK AGE 53's Avatar
You sure you're not hearing the rev limiter?
Al
Old Apr 12, 2004 | 10:26 AM
619SS's Avatar
k koo thx gonna check that out today..
Old Apr 12, 2004 | 12:03 PM
Loony's Avatar
Could it be pinging?
Old Apr 17, 2004 | 09:10 AM
obseSSion's Avatar
not sure but the first thing that comes to mind is detonation, sometimes called pre-ignition, spark knock, pinging, etc, this is a condition where the fuel air mixture, explodes too soon in the combustion chamber before the piston reaces top dead center, versus the "controlled burn" the is proper and intended, this could result from a few conditions. The car may be running lean, or too much initial timing , but the most common culprit is inferior, or LOW-OCTANE fuels, the little spot on the dash that says PREMIUM FUEL ONLY, yeah, they mean it, these cars are designed and tuned to run a minimum or 92 octane, and you cannot skimp, if this condition is not corrected, it will eventually cause piston/ring failure ESPECIALLY with the less than adequate pistons the the general stuffs in these engines. run your car until it is on E (low fuel) then fill it up with premium and add some O2 safe octane booster, and see if this cures the problem
Old Apr 19, 2004 | 11:42 AM
coogsLS1's Avatar
throw in some seafoam into the tank you have before you fill with premium, make sure everything is good and cleaned out. pick it up at local auto parts store for about 5 bucks.
Old Apr 19, 2004 | 12:00 PM
Drew98's Avatar
Originally posted by teke184
bent pushrod?
Thats what i'm thinking.
Old Apr 19, 2004 | 02:52 PM
coogsLS1's Avatar
when I had a bent push rod you could hear it at idle as well...
slowingsleeper
Apr 30, 2005 04:40 PM
skibbe_96z
Sep 27, 2004 02:03 PM
