LT1 Carb Manifold
Old Apr 29, 2005 | 09:24 PM
slowingsleeper's Avatar
LT1 Carb Manifold
Ok I read up on some of the threads on converting an LT1 to carb but I was planning on running forced induction so I wanted to run a single plane manifold so what would be a godo one to use?
Old Apr 29, 2005 | 11:37 PM
Alvin@pcmforless.com's Avatar
Re: LT1 Carb Manifold
blow threw carb?
Or
Single plane intake as a starting point for a EFI intake?
Old Apr 30, 2005 | 02:20 PM
For a blowthrough carb probably a holley 850 dp with twin pt76s and its being built for road racing.
Old Apr 30, 2005 | 04:40 PM
mrz28 73/97's Avatar
Just take whatever LT1 style heads you are going to use and get a Edelbrock Super Victor single plane and have your machince shop drill & tap your heads for the old style intake bolt pattern and away you go. As for the carb check out the Carb Shop they have carbs specifically modified for blow thru applications.
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
