What size jets should I be looking at running here?
Old Apr 9, 2004 | 01:02 PM
Serene's Avatar
Hey all
I'm looking to run a dual stage 100 shot for a total of 200hp on my motor. I have an NX nozzle and a NOS nozzle.
I have a bunch of jets here but i'm not sure what the power levels on each are rated at. Is there a formula to figure this out? I assume you would want to always assume high nitrous pressure and low fuel pressure? To keep from running lean?
If anyone can give me sizing for a 50 shot and a 100 shot that would be great!
Old Apr 9, 2004 | 03:53 PM
12Second3rdgen's Avatar
Re: What size jets should I be looking at running here?
Originally posted by Serene
Hey all
More nitrous and less fuel = lean
Too much fuel and not enough nitrous = rich
You want rich over lean.
Old Apr 9, 2004 | 04:03 PM
Serene's Avatar
which is exactly what i put. if you pick jets while assuming nitrous pressure is always 1200 or so and fuel is at 38 psi or whatever, you will be picking a nitrous jet that has a smaller hole, and a fuel jet that has a bigger hole, so you dont have to worry about overpressure nitrous situations, sure you may get less hp, but wont go lean.
hope that made sense.
Old Apr 9, 2004 | 06:31 PM
rskrause's Avatar
The search function is nice!
http://web.camaross.com/forums/showt...highlight=jets
Rich Krause
Old Apr 9, 2004 | 06:52 PM
Serene's Avatar
http://www.azsupersport.com/nitrousjetcalc.asp is that a fairly good calculator?
What should I be using as fuel pressure? Isnt it about 38psi?
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
1775.Z28
Jan 11, 2015 10:51 AM
bandit383lt4
Dec 21, 2014 09:12 PM
