4.00 Stroke?
Old Apr 1, 2004 | 01:00 PM
Deadcarny's Avatar
4.00 Stroke?
Has anybody been able to put a 4.000" Stroke crank in an LT1 block? I am getting ready to sell the 383 to help pay legal fees and figure that when I recover I want to either try something 'new' or start with an LS1. I was thinking of a 4.000" stroke on a 5.7" rod and 12.0-12.5:1 CR. that is all I have thought of so far. Not sure what heads yet and when I decide on heads I will get a cam to try to match them. Right now I was just wondering about the crank Combo. If it will work, will the block need a little more than just some 'massaging', or will a Grinder take care of all the clearancing I would need?
Old Apr 1, 2004 | 01:08 PM
SStrokerAce's Avatar
Well you can get one in a SBC block, but the depth of the LT1 cylinders will make a 4.00" stroke a bit of work. It has been done, and you would have to get a setup to work to fit everything in the block.
The Eagle 435340006000 crank needs 6.00" rods and a 1" compression height piston to work. That also means that the counter weights are going to be hanging out there so it's going to be an even tighter fit.
As I have said before I don't think the $ per HP are worth it when you go from a 383 to 396 to 408 are worth it.
Bret
Old Apr 1, 2004 | 01:21 PM
Deadcarny's Avatar
Actually, I considered a 6" rod at first. I thought that there may be a problem with the long rod and long stroke and the piston stalling for too long at the top and Bottom of the stroke.
Old Apr 1, 2004 | 02:07 PM
dnz28's Avatar
or if you got to go big 3.85 stroke and sleeve the cylinders. that would allow for a lot larger piston. and you would still have you 400+ cubes.
Old Apr 1, 2004 | 02:18 PM
One of the engine shops was selling an LT1 409ci short block... 4.00X4.030, but they no longer show it in their online catalog. Makes you wonder why.
A former member here claim to have built a 4.00x4.090 "421" and a 4.125x4.030 "421", so it has been done. There's also someone that posts here occasionally who claims to have a sleeved 4.00x4.120 LT1 "427".
Its just a matter of how much effort you want to invest in it for the unique ability to say "I have an LT1 4XX cubic inch engine."
Old Apr 1, 2004 | 02:39 PM
OldSStroker's Avatar
A former member here claims to have built a 4.00x4.090 "421" and a 4.125x4.030 "421", so it has been done. There's also someone that posts here occasionally who claims to have a sleeved 4.00x4.120 LT1 "427".
I read effort as money.
Old Apr 1, 2004 | 03:08 PM
rskrause's Avatar
Put the money in the heads and valvetrain rather than trying to go that big. You will get more bang for your buck.
Rich Krause
Old Apr 1, 2004 | 04:54 PM
Deadcarny's Avatar
I just did not think that the cost would be 'too much' more for a larger stroke Forged crank over a Stock stroke Forged crank. I am pretty sure the price is near the same. I figured most of the added cost would be in clearancing or extra machine work.
Old Apr 2, 2004 | 12:42 AM
And custom pistons, less choices when you go beyon 355 and 383
Old Apr 2, 2004 | 05:34 AM
Deadcarny's Avatar
Hmmmm. I guess I was figuring that the pistons might be only 50-60 bucks more than a normal 3.850 stroke piston set.
Old Apr 2, 2004 | 11:13 AM
Jason Short's Avatar
I have a 4" stroke crank in my new motor (LT1). Easy when you use the right parts and costs no more than a 383/396.
Old Apr 2, 2004 | 12:25 PM
Prorac1's Avatar
...................well tell the folks at home more about it Johnny. Seriously.............im curious about this 4 inch stroke. How did you make it work jason. Thanks Prorac1
Old Apr 2, 2004 | 09:10 PM
Steve in Seattle's Avatar
Use 383 pistons for 6" rods, but back off to a 5.85 rod... then get a 4" crank and some copper gastkets.
The slug will be 0.025" out of the hole, and some 0.065" gaskets will get you great quench.
Going 30-over, with the 4" crank you'll have a 408ci LT1, using off the shelf parts (assuming you have a 4" crank).
Clearancing will be a PITA, and you may even end up trying a few different sets of conrods...
The big question of course, is: what heads will you get to feed it?
I'm gonna have enough problems hoggin out LT1 castings to feed a 383 I'm building... fortunately I'm going with a small backup plan (Weisco pistons with reliefs to fit 23 AND 18* valves).
Power's in the heads... smart money's there to start.
Old Apr 2, 2004 | 11:16 PM
there is the point, power is in the HEADS!
Nothing wrong with a 1.00" compression height piston really and it's much better than the piston sticking way up into the gasket. I'd rather have a really thin gasket and the piston in the hole.
Bret
Old Apr 3, 2004 | 12:20 AM
rskrause's Avatar
I know of more than one LT1 block where clearancing for even a 383 (3.75" stroke) hit water. I think that if you didn't hit the water jacket when clearancing for a 4" stroke, no matter what rods you had, you were lucky. And even then, I think you would some pretty thin metal there. The Lunati Pro Mod rods seem to have good clearance. They are better in that respect than Eagle H-beam and Crower rods. The best rods I have seen for clearance are the Oliver billet I-beam rods. Most motors don't need these, which is good considering the price. But on my new motor I am using a set and they required very minimal clearancing. Almost none in some places.
In an NA motor the relatively high revs needed to make power will come into play when considering a long stroke motor. At 7,000rpm a 4" stroke and a 6" rod will produce a max piston speed of 4,648f/s and a max acceleration of 119,384f/s^2. With a 3.75" and 3.48" stroke and a 6" rods the numbers are 4,357 and 110,174 and 4,043 and 100,489 respectively. For a street motor these differences are significant.
I think a 4" stroke is too long. Jason, and other knowedgable people obviously don't think it's an issue. But if I wanted a 4" stroke small block I would use the lightest pistons and stongest rod bolts I could find. And definitely a 6" rod, though the difference in acceleration is small I think every bit may help.
Rich Krause
