conversion to msd distributor(wiring)
Old Mar 31, 2004 | 04:52 PM
tubby's Avatar
i'm switching my motor over to msd distributor - crank trigger.
i sent my FAST unit back for the conversion. also i should note that i have the harness adapter form white racing to keep my factory harness.
question is : there are two wires coming from the distributor and two coming from the crank trigger. i feel certain one set must plug into my msd 6btm box but which one and what about the other.
keep in mind i am one step below a moron when it comes to wiring so type very slow.
thanks
Old Apr 1, 2004 | 09:37 AM
96Z28SS's Avatar
Do you have a Bank to Bank system or Sequential?
If you have a sequencial then you need to run a crank trigger off the balancer and use the pick up in the distributor for the cam sync. In the distributor there will be a wheel with 8 prongs sticking out you need to cut 7 of them off so that it only sees the number 1.
If you have a bank to bank and your using the pick up in the distributor for the crank trigger, then you need to send those wires off the distributor to the FAST unit, you also need to send the points wire from the ignition box to the FAST unit.
X3 is the points wire
A3 is crank +
B3 is crank -
I also put a distributor in my car.
Rob
Old Apr 5, 2004 | 07:18 AM
tubby's Avatar
so with the bank to bank, which is what i have, are you saying i don't need a crank trigger?
what if i already mounted a crank trigger on it? can i use it?
how do you know which is X,A, & B? . i don't have my FAST unit with me are they marked?
Old Apr 5, 2004 | 08:18 AM
Brady's Avatar
You can use the crank trigger.
Which distributor do you have? I use the MSD# 8489.
Your harness from White Racing probably won't have the crank tirgger connector on it, you'll have to wire that yourself. Rob told you the pinout for the crank trigger, I think it's A3 and B3.
So it's really pretty simple, wire from the crank trigger to the FAST (twisted pair, shielded). then wire the points wire from the FAST to the MSD box. (white wire). Hook up the coil and go. With your crank trigger, the ONLY thing connecting to the distributor is the coil wire.
1 more thing, you will need to set the crank trigger pickup over a magnet at 50* BTDC, then in C-com (under "system configuration") set the "Crank Ref. Angle (*BTDC)" to 50.
here is a pic with the pinout labled, near the bottom.
www.teamprickracing.com/fasttrack6.jpg
good luck!
Old Apr 5, 2004 | 09:01 AM
96Z28SS's Avatar
Thats fine if your running a crank trigger mounted on the balancer.
only thing you need to wire on the distributor is the sparkplugs and the wire to the coil. thats it.
You probably have a distributor with a little wire harness coming out the bottom of it, you don't need to use that.
Also not sure if you know or not but you need to take the distributor apart and lock the timing advance, you don't want it to advance the timing, you'd be scratching your head when you went to tune the car.
Rob
Old Apr 5, 2004 | 11:00 AM
tubby's Avatar
thanks,
yes i did lock the advance.
one more question. i had to mount my pickup on the drivers side of the block and with the motor at 50 deg. BTDC i can't reach a magnet. is there another procedure i can use or do i need to machine a new brkt.?
Old Apr 7, 2004 | 09:58 AM
tubby's Avatar
okay i have the crank trigger all mounted at 50 deg btdc. still have some confusion on how i know which pin is a,b, or x the pic you sent illustrates how the numbered but if i'm looking at the back of the fast unit is it laid out just like the pic? sorry, just want to make sure i have it right.
thanks
Old Apr 7, 2004 | 12:51 PM
96Z28SS's Avatar
okay on the harness that plugs into the FAST box the alphabet is listed across the top get a flashlight and squint your eyes if you have to they are there just hard to see. and the numbers are number top to bottom, again they are there just real hard to see.
Old Apr 7, 2004 | 01:50 PM
tubby's Avatar
found them, flashlight hell you should have told me to get a microscope!!!!!! LOL
thanks
Old Apr 7, 2004 | 03:23 PM
tubby's Avatar
one final question, i want to use the same terminal wire ends when i wire in the 3 pins. where can i find these? i'm talking about the tiny square female ends that are barbed.
Old Apr 7, 2004 | 05:59 PM
96Z28SS's Avatar
i got them from FAST
Old Apr 8, 2004 | 06:55 AM
tubby's Avatar
was there a specific p/n? i called and talked to mike and he said i should be able to get them at a GM dealer. yeah right.... after having two dealers look at me like i'm form another planet i tried mike's next suggestion , NAPA, struck out there also.
Old Apr 8, 2004 | 12:10 PM
96Z28SS's Avatar
I don't know what the gm part number would be?
I got some from Power and Signal Group as a sample also.
They have a part number 12103881 which looks like a GM part number also so that might be it. Also P&SG used to be a delphi division. http://www.powerandsignal.com is the website i got some samples from but it took a couple months for me to get them.
Old Apr 8, 2004 | 12:25 PM
tubby's Avatar
thanks for the info. i may be on to something with napa will know for sure this afternoon.
update: napa did have the pins. distributor seems to be working fine . no more opti!!!!!!!!!
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
RedLineRev
Jan 23, 2003 03:51 PM
