Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Looking to upgrade your injectors and fuel pump ? Details inside ...
Old Mar 30, 2004 | 02:15 AM
New Era's Avatar
We have have the following fuel system components on special right now :
Bosch #30 injectors (set of 8) - $229
Bosch #42 injectors (set of 8) - $289
Sieman Deka #60 injectors (set of 8) - $499
Walbro 255 lph high pressure pump (In-Tank) - $99
Walbro 255 lph High pressure pump (In-Line) - $129
Universal liquid filled fuel pressure guage - $19
All these injectors are High Impedence and require no injector driver modifications .
These can all be ordered online at these prices right now at www.neweraperformanceparts.com .
Thanks,
Mike
sales@neweraperformanceparts.com
Old Mar 30, 2004 | 02:52 AM
hsyr's Avatar
For the Walbro 255l intake how much HP can it support and how would you know what you need between a low pressure and high pressure version?
Old Mar 30, 2004 | 06:01 AM
New Era's Avatar
The high pressure will support about 600 hp , the standard will support about 500 hp .
The high pressure pump's effieciency is 60-100 psi , the standard pump's efficiency is up to 60 psi .
Thanks,
Mike
Old Mar 31, 2004 | 08:13 AM
CJ Black LS1 Z28 M6's Avatar
Thumbs up
I ordered one from u guys last year for my 94 Z just brought another Z and ordering another How long is the special on for? Thanks
Old Mar 31, 2004 | 04:54 PM
Serene's Avatar
how much work are these to get to fit the cars? direct bolt in?
Old Mar 31, 2004 | 05:17 PM
New Era's Avatar
They are a direct fit , I am unsure when the special will end , the pumps will probably stay at that price , but the injectors are going up .
Thanks ,
Mike
Old Mar 31, 2004 | 05:52 PM
hsyr's Avatar
When and if my income tax ever comes I'm definatley in for a Walbro 255L intank. What exactly does it come with?
Old Mar 31, 2004 | 07:06 PM
Dave88LX's Avatar
From what I understand, Bosch makes SVO injectors. Does that also mean that Bosch injectors are rated at the same PSI as SVO injectors?
What are they rated at?
Thanks!
Dave
Old Apr 1, 2004 | 05:55 AM
New Era's Avatar
Yes , the Bosch and svo injectors are the same thing .
Thanks,
Mike
Old Apr 1, 2004 | 05:19 PM
SS MPSTR's Avatar
Re: Looking to upgrade your injectors and fuel pump ? Details inside ...
Thanks,
Mike
The website indicates that the 42# injectors are another price. They are $289 as indicated above, right?
Old Apr 1, 2004 | 06:05 PM
simple's Avatar
details on what is needed to get the inline pump to work?
-AN lines or will it work with stock fuel lines?
you say the intank pump is a direct fit?
Old Apr 1, 2004 | 08:29 PM
New Era's Avatar
The Bosch #42's are now out of stock , the price has now gone up quite a bit . If you would like more info please email us sales@neweraperformanceparts.com
The in-tank pump will fit and comes with an installation kit including a piece of fuel line , 2 ss clamps , a wire harness with 2 wire connectors , and a filter sock for the pick up . There may be some modification to the sending unit required to complete installation depending on application . Just search the boards and you will see .
The pumps are going up this time because our cost has now gone up , there is only 6 left at this price .
There is a picture on the website with the universal installation kit that comes with the in-line pump which will show you what it uses , they are not AN style fittings .
Thanks ,
Mike
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
