Dash lights......
Old Mar 29, 2004 | 01:44 PM
Schismblade's Avatar
Dash lights......
Hey, I was wondering if anyone knew how to change the lights in the dash? I bought some white guages and decided not to put them on, and I want to just change the back light. Can anyone help?
Old Mar 29, 2004 | 06:21 PM
99blackSS's Avatar
I don't know how to get to the actual bulbs but to get the cluster out you unscrew the two bolts that are screwed in vertically above the steering column. Then you pull off that bezel piece, you have to play with it a little to get it off the steering column. Then there is going to be two bolts under the gauges and I believe there is also two above it, unscrew those. Then the cluster will simple pull out, there's no wires, it's all wired through a computer prong thing.
That is the part I know for sure, I put in white face gauges, not bulbs. Hopefully by looking at the cluster you will be able to find a way to get to the bulbs. If you do decide to go ahead and put in the white face gauges, write down where the needles point before you take out the cluster.
David Dempsey
Mar 12, 2016 12:42 AM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
