'78 block FI conversion options.
Old Sep 7, 2002 | 06:24 PM
KCFormula's Avatar
Post '78 block FI conversion options.
I have a '78 Chevy block that, when I got it had 400 sb heads on it. Well I rebilt the bottom end and found some 350 heads with 2.02/1.56 valves but the heads dont have any port work done at all.
I would like to know if I could slap a TPI intake with injectors on it? Besides the computer what other accesories would I have to swap? Would it even bolt up?
Thanks for the help in advance. I plan on putting this motor in a 4th gen.
Old Sep 8, 2002 | 03:27 PM
BlackHawk T/A's Avatar
Check these guys out.
www.tpis.com
Look at their "Mini-Ram". You can also get the wire harness, injectors, custom PROM, and fuel rails from them.
Edit: You can order a free catalog too .
[This message has been edited by BlackHawk T/A (edited September 08, 2002).]
Old Sep 8, 2002 | 05:28 PM
LT1 1980 malibu's Avatar
Dont think that a tpi will fit under the hood of a 4th gen..
If you get the dist and all the sensors on the block and heads you will have little problems..
Ive done it about 29 times before..Now to make it fit id suggest that you look into some of the carb intakes setup for injection..Run a 4bbl throttle body on it or run the TPI throttle body with an elbow to adapt it to the carb pad..Ive done that before on a few stangs before and it would work great on a chevy..The only thing that your changing is the intake manifold..
FLUCK A SPELL CHECK<I CAN SPELL REALLY GOOD< IT'S JUST THE TYPEING THAT STINK AT!
http://phillyfabanddesign.tripod.com/parts4sale/
http://phillyfabanddesign.tripod.com/phillyfabricationanddesign/
http://phillyfabanddesign.tripod.com/PhillyFabsLT1RX7/id1.html
88 RX7 GTU, 97 Lt1/700R4,10" 3K stall, 4.30 gears,285CFM heads,12.4-1 compression, custom cam and 2700lbs...Daily driven!
Old Sep 8, 2002 | 11:38 PM
cy Z28's Avatar
how fast are you planning on going?
The only reason to take a traditional small block over an LT/LS is that you're wanting Splayed valve heads or some kind of funky big block. As far as accessibility goes and the whatnot, you're far better off with an LT1 because of the ignition system being in the front of the motor. My suggestion would be to either trade off for a Gen2 block and a DFI setup. Or sell that motor and invest in the DFI and H/C.
That unported motor will make less HP than a stock LT1 (w/ the same mods) and the mods are availible to bolt on to the LT1. It's not like parts availibility is an issue.
Just my .02
Cody "cy Z28"
1984 Camaro Z28 "black on black on chrome". Reher-Morrison built 383 stroker. Scat crank and rods, JE pistons, all comp valvetrain, Manley valves, Comp 252/258 .608/.619" 110 LSA camshaft. GM aluminum ZZ4 heads w/ Reher-Morrison porting, Tpis MINI-RAM intake, Accell DFI, 30lb injectors, 58mm TB, Aluminum Radiator, BW T-56 swapped in, Kevlar clutch, Pro 5.0 shifter, Aluminum DS, richmind 3.73's, Torsen diff, 30 spline axles, 4 wheel disk brakes, Full suspension from Spohn, ES bushings up front, Rod-ends out back, Addco Swaybars, 75dry/125wet two stage nitrous system.
**STILL UNDER CONSTRUCTION**
Update: Motor makes 557hp/503tq on Desktop Dyno 2000. Let's see if I can get it tuned that well
Henson071
Sep 18, 2015 04:01 PM
cmsmith
Sep 14, 2015 09:25 PM
cmsmith
Aug 27, 2015 06:37 PM
cmsmith
Aug 20, 2015 07:57 PM
pimpen1024
Aug 19, 2015 08:36 PM
