TH350 short/long tailshaft
Old Mar 12, 2004 | 02:57 PM
shwine617's Avatar
I have a turbo350 for my car with the short tailshaft.
If I were to buy a long tailshaft would it just bolt right up to my trans? what has to be done to switch the tailshafts? I already got the B&M kit for the crossmember and torque arm, but now I am stuck on the driveshaft/tailshaft situation.
thanks for the help!!
Old Mar 12, 2004 | 06:32 PM
Stephen 87 IROC's Avatar
The short tailshaft is 6" long. The long tailshaft is 9" long. The difference isn't just the housing but the output shaft in the tranny. You can switch it over but that means pulling the tranny and stripping it right down to the back end. When reassembling, the tailshaft goes in first then all the rest of the internal parts.
If you already have a short tailshaft and driveshaft then why would you want to switch to a long tailshaft and use a shorter driveshaft? The B&M torque arm kit attaches to the rear housing mount bolts so that position doesn't change. The only thing that may affect you is if you have a driveshaft loop. It has to be within 6" of the u-joint. If you put the longer tranny in, the loop will be in the wrong position.
Old Mar 13, 2004 | 05:02 PM
1984camaroz28's Avatar
wrong the short tail is 4in long and the long tail is 6in long the short tail is 2in longer..... short tail th350 is the same length as a turbo 400
Old Mar 18, 2004 | 12:53 AM
c1989rs's Avatar
on an 85-92 camaro if u dont want to have to get a new driveshaft it is best to use a long tail trans i had a long tail 350 in my 89 and all i had to get is the conversion kit for the tq arm and trans mount b&m makes it
Old Mar 18, 2004 | 03:23 AM
udlooz's Avatar
350 tails
short tailshaft is 6" intermediate is 9" and longtail is 12".i just did the swap using a intermediate tail.used the stock driveline.it would probably be best for you to get your driveshaft lengthened or get one out of an 82' with a 200 trans.
Old Mar 18, 2004 | 08:10 AM
Re: 350 tails
LOL
Old Mar 19, 2004 | 12:52 AM
udlooz's Avatar
lol
lmao
Old Mar 19, 2004 | 08:19 AM
long tail is 6 and short tail is 4 Look in summit man
Old Mar 20, 2004 | 07:09 AM
udlooz's Avatar
not to flame but your wrong on the tailshaft sizes.i have been building 350th's since before the 3rd gens existed.6",9" and the rare 12".there is no 4".the only thing shorter than a 6" is the 4wd tail.i think you may be confusing it with a 400th which does have a 4" tail,but is the same overall length as a 350 w/6" tail.
Old Mar 20, 2004 | 09:31 AM
im sry w/e you no everything
Old Mar 20, 2004 | 03:16 PM
TravisA's Avatar
http://www.taekwondoplus.org/z28/m6_to_th350_swap.htm
Try this
Travis
Old Mar 22, 2004 | 10:27 PM
c1989rs's Avatar
the guy didnt ask what the size is of the tail shaft is. what would make it easy to do the swap. i have done the swap and used my stock 700r4 drive shaft out of an 89 camaro. the 350 trans that i used waz a long tail and i had no problems with it going in. buy the conversion kit and it should go fine. if u have a short tail get a drive shaft made.
james4154
Jun 15, 2015 12:16 PM
IROC86
Jan 5, 2003 01:09 AM
OrangeIROC
Nov 21, 2002 01:54 PM
OrangeIROC
Nov 17, 2002 10:18 PM
The Big Show
West South Central
Oct 28, 2002 09:53 AM
