Flex fan or dual electrics?
Old Mar 12, 2004 | 02:20 PM
kbog54's Avatar
Hey, I was thinking about getting rid of my stock fan on my '83 Z because I know that it robs alot of power. The fan is the original factory fan with a fluid clutch. I was wondering if it would be worth it to put a flex fan in, or if it would be better to just go with dual electric fans.
The only problem I would see with the electrics would be overloading my alternator since I'm running underbody neons aftermarket fog lights and two amps. Would a 140 amp alternator fix this problem?
thanks
Old Mar 12, 2004 | 02:38 PM
IROC-T's Avatar
I would go with electric if possible,add up the total amps you are drawing plus what the fans draw,if under 140 the the bigger altennator should handle everything fine. I would only go with a flex fan if that was only way.
Old Mar 12, 2004 | 05:09 PM
aklim's Avatar
I doubt it will overload you alternator. They don't draw that much power and you aren't having both of them on all the time anyways, are you?
Richardan15
May 30, 2015 08:36 AM
Mar 15, 2015 07:01 PM
4586
Dec 31, 2014 02:21 PM
