scanmaster accuracy
Old Sep 12, 2002 | 10:55 AM
BPS's Avatar
BPS
Post scanmaster accuracy
I'm having some charging issues and was wondering if the scanmaster readout for BAT was equal to that which would be measured using a voltmeter at the battery?
My alternator runnin below the halfway mark and the scanmaster indicates that the BAT values fall from about 13.5 at startup to 12.3 at idle over a 5 minute period.
Old Sep 12, 2002 | 11:00 AM
I've noticed some discrepancies on the "volt" reading from the ScanMaster. It seems to read lower than the dash gauge, and it also seems to read lower than the "volt" reading from my MoTeC engine management computer. Appears each one is reading voltage at a different point in the system.
In any case, the difference is simply that the ScanMaster just reads lower than the other two by about 0.5V-1.0V. If the system voltage falls off, it falls on the SM, the gauge and in the MoTeC.
Fred
94 Formula A3+1: 381/TH400+OD/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Sep 12, 2002 | 01:42 PM
95ImpalaSS's Avatar
The Scanmaster is probably reporting what the PCM is telling it since voltage is one of the parameters in the data stream.
The voltage to the PCM may be lower because of a drop going through the ignition switch and wiring harness.
Peytons'z
May 6, 2021 09:25 AM
marlar98
Sep 12, 2018 07:18 AM
marlar98
Sep 19, 2015 07:53 AM
blmw
Jun 14, 2015 05:20 PM
Shon Herron
Mar 18, 2003 12:18 PM
