code P1351 anybody?
Old Sep 11, 2002 | 05:32 PM
sharp28's Avatar
Post code P1351 anybody?
P1351-- Ignition coil control circuit high voltage
Has anybody dealt with this code before?
Old Sep 11, 2002 | 07:03 PM
kmook's Avatar
Advanced Tech Moderator
I see you have a 96Z in another post, I will get this over to 'Computer diagnostics/programming' where its more suited.
Thanks.
Ken Mook - 97' SS #2544
Advanced Tech Posting Guidelines
  • 383 - D1, CAS Custom I/C System, 74# Siemens, LJ's Black Box,
  • Kenne Bell Boost-a-pump, Stage 2 Heads, 3100 Lobe XE Cam, Godzilla BOV,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
[This message has been edited by kmook (edited September 11, 2002).]
Old Sep 20, 2002 | 03:22 PM
sharp28's Avatar
problem solved! replaced coil and coil wire, code went away. Also moved the coil bracket away from the head, but i don't think that had anything to do with it
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
