Blower .bin files.
Old Jul 21, 2002 | 04:26 PM
TravisA's Avatar
Post Blower .bin files.
I was wondering if anyone has any .bin files for a blown car they could post or email. I was just looking for some files i could look at to help get my car tuned in. Car is in sig if that helps.
Thanks for any help.
Travis
1994 Z28 M6 Hardtop
355 LT1, Forged H-beam rods, Speed-Pro Blower Pistons,Speed Pro Rings,Pistons,Clevite 77 Bearings, Comp Cams 218/230 .528/.544, comp 987 springs, titanium retainers, 10* locks, comp cams 1.6 RR's, CSI Water pump,MSD 6AL,Cloyes Double Roller, Hooker LT's, True 3" Dual Exhaust with Delta Force Flowmasters, Spec Stage III Clutch,Relocated MAF, 42lb SVO's,12psi ATI Procharger.
Old Jul 22, 2002 | 11:25 AM
robertf97's Avatar
I just got the tunercat license today. If you want my bin file, e-mail me and I'll try to get it to you.
It's lean at idle but looks OK at cruise and good at WOT. It's for 36lb injectors no FMU with 6 psi. If you've got bigger injectors it might work well for you.
Supercharged 94 Formula Coupe M6, 355ci LT1 10.2CR, 6 psi PD, 218/230/114, 1.6RR, 36lb/hr, TRW L2256F, PM rods, ARP rod bolts and 2 bolt main studs, mild port and polish, 1.94/1.50 Race Flo valves, MSD 6BTM, CSI electric WP, Ed Wright tuning, inline fuel pump, Pacesetter 1 5/8” mid length headers, MAC catback, Torque arm & SFC’s, AL DS, LCA’s, PHR, big *** sway bars
Old Aug 20, 2005 | 12:08 PM
mmdehaven's Avatar
Re: Blower .bin files.
If ya find any Tunercat blower bins out there, could you share the wealth. I am also in need of a blower file for a 388CI stroker, with an ATI 8psi kit,40lb injectors, hooker headers and catback, less the cat of course, and a 218/224 @114ls and a 108cl .528/.535 custom ground camshaft in a 6spd '94 TA. I need 500 miles on the motor before I can get it into the dyno for the official tune. I just need something close right now.
Thanks
Old Aug 21, 2005 | 02:51 AM
MEAN LT1's Avatar
Brent Franker has about two or three on his site.
AviatorDave
Dec 19, 2016 06:35 PM
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
whitehooptie
Jul 22, 2015 10:25 PM
dayusmc
N2O Tech
Sep 5, 2002 12:31 PM
