What grit sandpaper to use on stock wheel sanding for paint??
Old Feb 19, 2004 | 08:23 PM
Robbie's Avatar
Gonna paint my stock 5 spokes black and was wondering what grit sandpaper I should use? And should I use primer or will just sanding be fine?
Old Feb 20, 2004 | 12:50 PM
Z28SORR's Avatar
Re: What grit sandpaper to use on stock wheel sanding for paint??
This depends on what look you want. But the rule of thumb is at least a 400 grit before the top coat. Finer will get you a smoother finish but is more work. If you do not sand though the existing paint you don't "need" to primer.
Old Feb 20, 2004 | 02:06 PM
jorgez28's Avatar
Are you saying to just paint over the original finish with out sanding
Old Feb 20, 2004 | 03:24 PM
kameleon426's Avatar
you can just scuff it up with a scotch bright pad they sell them at almost any auto parts stores just scuff till u get a dull like finish and shot the paint and clear. if you use sand paper use at least 400 grit and try not to go all the way down to the metal cuz if you do then you have to primer them.
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
rjc1629
Jan 27, 2015 10:46 AM
rockync7
Jan 1, 2015 05:10 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
