How many 1/4 mile runs on 1 bottle?
Old Feb 6, 2004 | 06:24 PM
crb4osu's Avatar
How many 1/4 mile runs can I get out of a full 15lb bottle of n2o?
Old Feb 6, 2004 | 08:54 PM
rskrause's Avatar
100hp/10sec uses ~1lb. But you can't get 15lbs out of a 15lb bottle.
Rich Krause
Old Feb 6, 2004 | 10:35 PM
AutoRoc's Avatar
Past experience:
150 shot...mid-high 12 second runs, 2 SOLID runs and a third half assed low pressure run usually
100 shot and low 13's was getting about 3-4 good passes.
Finding a CHEAP source to fill the bottle is key once you figure out how much ya spend on every pass. hahaha
Old Feb 6, 2004 | 11:14 PM
Deadcarny's Avatar
i am hoping to get one good run with this 78 N2O NX jet i have in there now.....lol
Old Feb 7, 2004 | 04:04 PM
n20ta2's Avatar
Yor only getting 2.5 runs out of your bottle? I can get 5 solid runs sometimes six out of mine and im running 175 shot,pressure never drops below 925psi.I am heating the bottle with a warmer though.
Old Feb 7, 2004 | 11:16 PM
DrewHMS97SS's Avatar
second from what friends are doing, off a 10# and 100 shots though
Old Feb 8, 2004 | 08:48 AM
Deadcarny's Avatar
with my bolt on motor and with a 150 shot, I would get 3 11 sec runs with a warmer, but at the end of the 3rd would be a pressure drop. i am now setup with a 78 N2O jet, so I am hoping to get more than one run without a pressure drop on a second. 2 runs would be absolutely perfect.
Old Feb 8, 2004 | 01:58 PM
HOLLY **** that is a big jet for 150.....im running a .48 jet un mine.
Old Feb 8, 2004 | 02:01 PM
RacinLT1's Avatar
the 78 jet is for 200-250 somewhere in there.
i got 4-5 low 11 sec runs from a 10lb bottle with my 150 before pressure dropped.
I was getting 3-4 from a 10lb bottle on the 175.
yes i do use a heater AND a bottle blanket.
Old Feb 10, 2004 | 12:43 PM
BIGBADBOWTIE's Avatar
4-5 passes on a 150 .. Nitrous works plate....11.0x@125
Old Feb 10, 2004 | 03:29 PM
Deadcarny's Avatar
yup....
Old Feb 10, 2004 | 04:47 PM
SVT Killer LV's Avatar
JEEZ LOUISE... 78
Old Feb 11, 2004 | 10:58 AM
rahusband's Avatar
So is there anyway to add additional bottles to a single system? like for instance 3 15lb bottles??
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Lederman1976
Nov 30, 2014 05:21 AM
MustangEater82
19
Sep 3, 2002 02:09 PM
centric
Aug 15, 2002 09:04 PM
