please explain to me>>
Old Feb 2, 2004 | 06:59 AM
F(ast)-body's Avatar
I'm looking for the best way to put nitrous on my car. I've read about controllers that gradually increase the flow of nitrous so it's not all at once....money out the window here. How does that work, what setup is best, .....I want the best possible results from using nitrous...
Old Feb 2, 2004 | 08:37 AM
RacinLT1's Avatar
i used the old NX Maximizer progressive and had great luck with it.
it's a time based system that pulses the solenoids at varying speeds to increse the flow. the biggest problem with any progressive is that they beat up the solenoids by cycling them.
depending on how much nitrous you want to run,a 2 stage setup would be better,less wear on solenoids and you can jet each stage accordingly.
Old Feb 11, 2004 | 02:20 PM
Hawk's Avatar
to make it simple at first, I'd recomend a NX kit or other wet kit, get that on with all your recommended safety equipment. Once thats good to go, the maximizer is a nice addition to your system. But, like I said I recommend getting the basics first and learning how to use the spray before you decide on the maximizer. It's not a cheap toy and you may find you don't need it yet, .
Old Feb 11, 2004 | 02:43 PM
DrewHMS97SS's Avatar
i would do one of two things, if you buy the NX kit, buy a TNT plate to mount the nozzles in. i run the TNT kit personally and love what it does. I also use a maximizer, and have had not problems.
Nickster 7
Aug 27, 2015 10:12 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
War Engine
Aug 21, 2015 05:28 AM
350350
14
Aug 11, 2015 12:03 PM
NewsBot
Jul 29, 2015 08:10 PM
