What dosage, not an LT1
Old Jan 23, 2004 | 10:13 PM
12Second3rdgen's Avatar
Just curious what you guys would run on this setup. I have to make one more braided -8AN hose and I will be finished. It is:
350HO crate engine-
10:1 compression, ported/polished vortec heads, upgraded springs, XE274 camshaft, super victor intake, Speed Demon 650 carb, MSD Pro Billet Distributor, MSD 6A ignition, MSD blaster 2 coil.
Current best is 12.4 with that setup on radial tires.
Bottom end in the motor is:
Cast aluminum pistons (weak link)
Forged PM Steel Connecting rods
Nodular Iron crankshaft
The nitrous setup I am running is:
NOS cheater kit
Stand alone fuel system consisting of:
Jazz 1 gallon fuel cell
Holley Blue Fuel Pump and regulator with return
Safety Stuff:
Fuel pressure safety switch, competition engineering WOT switch, and a button.
The motor has under 5k miles on it. What do you guys think I should pill it for once I get the combo dialed in. I will be spraying race gas with the nitrous mix when I do spray.
Old Jan 24, 2004 | 01:05 PM
Mike383LT1's Avatar
how much
I,ve heard the expresion with n2o,start small and work up I would start with a 125 shot.I've seen this done on a stock lt1 outside of the pistons you have a little better bottom end
Old Jan 24, 2004 | 04:46 PM
DrewHMS97SS's Avatar
i would think that with the tiny bottle, you would want to run a smaller shot as to not have 2 secs of power
Old Jan 26, 2004 | 11:07 AM
10 lb bottle is small?
Old Jan 26, 2004 | 12:47 PM
thought you were talking about the cheater system with the 12oz bottle.
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Redbird
Jul 23, 2002 07:16 AM
