How to adjust LCA's for the track?
Old Jun 2, 2002 | 04:49 PM
snksknr94's Avatar
Question How to adjust LCA's for the track?
I just installed Spohn adjustable LCA's and panhard bar. How should I adjust these to best help 1/4 mile times? Lengthen? Shorten?
Thanks,
Aaron
Old Jun 2, 2002 | 05:10 PM
LPEdave's Avatar
You may want to post in the drag racing section, but I've never heard of shortening or lengthening LCA's for drag racing purposes. Dropping them lower on LCA brackets, yes.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Jun 2, 2002 | 05:17 PM
snksknr94's Avatar
<font face="Verdana, Arial" size="2">Originally posted by LPEdave:
Dave
</font>
Yeah it didn't make much sense to me either but I figured they are adjustable so maybe it would make a difference. I guess it must just be mainly to keep the suspension in geometry.
Old Jun 4, 2002 | 09:18 AM
auto-Xer's Avatar
I think by moving them back farther (increasing their length), you can get a more negative pinion angle on the torque arm preloading it more. That could be good for drag racing, but this is just a guess.
--Kevin
Old Jun 4, 2002 | 11:14 PM
LPEdave's Avatar
<font face="Verdana, Arial" size="2">Originally posted by auto-Xer:
I think by moving them back farther (increasing their length), you can get a more negative pinion angle on the torque arm preloading it more. That could be good for drag racing, but this is just a guess.</font>
That's actually incorrect. The pinion angle is set between the torque arm and the rear end - the LCA's can't control it. Lengthening the LCA's would move your axle toward the rear...
Dave
Old Jun 14, 2002 | 08:47 PM
96z's Avatar
96z
Adjustable LCA's are mostly used to center a larger tire in the wheel well namely drag slicks.
96 black Z28 A4
GTP stage II heads, GTP 226/230 cam, 11:1 CR, Pro Torque 2800 TC, Tranny cooler, 3.42, 1.6 rr, Holley 58mm TB, Hooker LT's, SLP CAI, cutout, Flowmaster, Wolfe cage, Carrera's, 5 point belts
Mattucci Motorsports WNYFA FLFB
Pics Anybody else need earplugs when they drive????
96SilverRam
Nov 20, 2016 11:19 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
