question about the pro 5.0 shifter
Old Jan 17, 2004 | 07:50 PM
rlax31's Avatar
I just put on a short stick on my stock hurst shifter, as you know the stock stick is offset, but the one I have now is not. You can see the difference here.
Now the stick sits way on the right side of the console area, which is a little annoying.
So on to my question, I've decided to buy a pro 5.0 shifter, and I was wondering if the place where you connect the stick to the shifter is angles toward the driver at all? It kind of looks like it does in this picture.
Idealy I like to use the Pro 5.0 and the short stick I have now, and have the stick extending from the center of the console area without fabbing some sort of offset.
Thanks
Old Jan 17, 2004 | 11:46 PM
Dan K's Avatar
If you get the Pro 5.0 just use the stock stick and cut some of the threaded end off of it. That's all I did and I absolutely love it.
Old Jan 18, 2004 | 03:56 PM
zuluman13's Avatar
i have a pro 5.0 and short stick and mine was angled where it connects to the shifter but the short stick is different for each shifter it says that on his site i dont know if you can modify it to work though you will have to email him.
Old Jan 18, 2004 | 07:39 PM
chpmnsws6's Avatar
use the stick that comes with the pro 5.0 and just cut it down. anymore than that and you will be reaching down into the shifter boot to make ur shift
then you can sell the stick you have now and make up some of what you lost buying the pro 5.0
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
