what would keep reverse from gong in??
Old Jan 17, 2004 | 03:27 PM
1.8ttolt1's Avatar
i assumed the synchros weren't lining up, but i was told reverse isn't sychronized. i can get it in sometimes, other times it won't go in, and i have to roll forward a little before i can get it in. then sometimes i have to hold it in so it doesn't pop out. the rest of the gears are fine though. any input.
Old Jan 18, 2004 | 12:42 PM
1.8ttolt1's Avatar
anyone?
Old Jan 18, 2004 | 10:42 PM
You might want to mention what specific tranny you are talking about.
Old Jan 19, 2004 | 12:47 AM
PatriotTA's Avatar
If you are talking about an M6 (manual trans), try double clutching going to reverse and that may help. Also, instead of shifting into reverse right after you floor the clutch, wait a few seconds with the clutch depressed before shifting into reverse. HTH.
Old Jan 19, 2004 | 06:19 AM
1.8ttolt1's Avatar
sorry, m6
Old Jan 19, 2004 | 09:33 PM
slashz28's Avatar
mine used to do that as well. if id put it in third, then reverse, itd work fine. (it was either first or third , cant remember, but im almost positive it was third). i had given this trick to soemone else who had the same prob and it worked for them as well. hth
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
Beave2780
Jul 7, 2015 06:36 AM
