New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
DYNO NUMBERS ON 383 procharged camaro
Old Jul 15, 2002 | 01:49 PM
9SECONDLX's Avatar
Post DYNO NUMBERS ON 383 procharged camaro
on friday i ran my camaro through a local dyno just to see what it did. its a bitter sweet story.
i did not tune it. (im going to have dean look at it.) i just want to get a base line and check my fuel curve to make sure it was safe. (eds wrights fuel curve was very good. it s almost a straight line across. it even ran richer at higher rpms, not bad out of the box.)
here is the breakdown,
with 6-7pds of boost and a very restrictive 1 5/8 street exhaust system along with a cat,pumped gas, an an air temp of 83 degrees it made 460 rwh and 463pds of torque consistanly within 1 to 2 horsepower over 4 runs. we let it cool down about 10 minutes between each run..
at first i was not to happy but then i realized that the motor really needs to breath better for a blower car and the boost was level was very low.
lets just say!!!!!!
today i ordered hooker long tube headers and im getting my friend to coat them for me. im also going to make a custom h pipe with no cats for it and im having ASP custom make me a 17pd blower pulley so i should see 14 pds of boost after the inner cooler and 383 take a few pds.. procharger stops making them at 15pds.(2.55)
im looking to break into the 600hp range for ned's next dyno day. im praying to pick up 140hp with 6-7 more pds of boost and a much freer exhaust.
even if i get close to those numbers i will be happy considering im using a small blower and a small cam. i know my bottom end can handle it easily.
thanks for listening dennis
9 second street legal 1989 mustang lx, special effects purple, 306 Vortech t trim 20pds of boost, momo; seats-steering wheel and shifter ****, weld drag lites, stage 2 fuel system, cervini stormin normin hood and saleen wing, tfs ported heads and edelbrock rpm intake, 8pt cage.
new project, 1994 Z28, 383 stroker, 4 bolt block with bullet main caps, cola light weight crank, H beam eagle rods, je inverted pistons 9.2 compression with heads, comp cam custom grind cam and 1.6 non self-aligning rockers, afr stage 2 heads 58cc, fully ported LT1 intake powder coated LT4 red, 3 core race intercooler, polished procharger, 3:73 gears, custom torque arm, eibach springs, custom panhard bar and control arms, kyb agx adjustable shocks, ss hood, factory ss spoiler, 58mm bbk throttlebody, B&M ripper shifter, chrome zr1 rims, autometer phantom gauges, edelbrock headers,
Old Jul 15, 2002 | 02:06 PM
bowtiepwr's Avatar
>cool Dennis ,
I'm glad everything is working out with the new set up .I understand that you have both Mustang and Camaro ... what do you use in the winter ?
Later ...
stay safe
Old Jul 15, 2002 | 02:10 PM
9SECONDLX's Avatar
last year i bought an 89 dodge shadow for 200 but it died in february (head gasket). so i pulled the stang out of storage and drove that. thank god it did not snow...the camaro wasnt ready yet. my girlfriend has a saab convt so i drove that when i need to.
im going to have to start looking for a new winter beater soon.!!!
when are you coming back?
Old Jul 15, 2002 | 02:57 PM
bowtiepwr's Avatar
>I'm back now since the 12th of July ... they pulled us back because they are going to do something else . I can't say , and I don't know the time frame , but bet your boots somethings going to happen .
Later ...
stay safe
Old Jul 15, 2002 | 03:54 PM
jayman350's Avatar
wow man sounds like you've got another mean car there
I'm definately looking forward to seeing this at the next dyno day
Jay
black 85 Z28 - waiting on a new paint job, then she'll be real purty
87 Chevy S10 Blazer- 2.8 liters of pure fury
Jay's Website
yahoo im: wildcat856
AIM: Jayman85Z
Homer no function beer well without
check out GMPerformance.org
Old Jul 15, 2002 | 07:39 PM
Vortech396's Avatar
Sounds good so far Dennis
seeya
John
John
My Blown396Z site
Silver 96 Z/28,6 spd.
Team NEDyno/Quest Racing supercharged 398 in progress
Old Jul 16, 2002 | 08:24 AM
1st and goal's Avatar
Not too shabby
Refresh me on your blower setup....P600? and how much boost is the pulley you have now rated for?
94 Z/28, 383 D-1
Marc's Blown 94 Z/28 "Want it, Have it, Have it, Want it"
Old Jul 16, 2002 | 09:24 AM
9SECONDLX's Avatar
Hi marc
The pulley that is on there i think is the 12lb pulley. with the 383 and the 3 core inner cooler it takes away form the boost. as you probably know.
im going to have asp make me a 17pd pulley so im hoping to get 13pds of boost. i have the p600b. i know i need a bigger blower but i dont want to spend the 2000 right now. even with the 17pd pulley i am still under 60000 revs on the blower. if it blows, it blows. i dont drive hard all the time so i think im ok.
how are you coming.
Old Jul 16, 2002 | 10:22 AM
<font face="Verdana, Arial" size="2">Originally posted by 9SECONDLX:
Hi marc
how are you coming.
</font>
A P600B can handle a 15# pulley for 6400 rpm and then it's "Danger, Danger Will Robinson" and the little robot slinging it's arms in the air
It's not how much boost you're making it's how fast the impeller is spinning. I would not come close to max blower speed as you're loosing effeciency. Why don't you concentrate on inproving airflow on the intake side. Move the MAF to the pressureized side and fab up a 4" intake and 4 x 12 K&N filter? or at least fab up a solid 3 1/2 tube and get a larger filter. I would not go larger than a 15 # pulley.
My Z is maturing like a fine wine
It's making progress and will be done by early August.
Marc
94 Z/28, 383 D-1
Old Jul 16, 2002 | 10:23 AM
9SECONDLX's Avatar
are you going to the camaro show in boston sunday, ed is coming up and i think jeffsworld is also. i live about 5 minutes from the museum of trans.
Old Jul 16, 2002 | 10:31 AM
9SECONDLX's Avatar
marc
your right in what your saying but my motor will never 6400 rpm. (cam wont do it.) when i dynoed it the max horsepower and torque was aroung 5600 rpms, after that it lost power. if i run the 17pd pulley and keep it under the 6000 rpm the propeller is less than the 60,000 revs the blower is able to handle.
what type of rpms are you planning on turning?
Old Jul 17, 2002 | 07:55 AM
Not going to the camaro show.
Going to see what it dyno's at to determine redline but not planning on revving the **** out of it. If I had to guess I'd say ~6000-6200 at the track and in the 5's on the street (will be able to set up different programs for my T-com).
Even if you keep it under the 60K I'd still be concerned about the effeciency of maxing the blower out. I'd also be concerned about belt slippage if you go to a smaller pulley some people have belt slippage on a 15# pulley let alone going even smaller.
Did you give any thoughts to improving the airflow on the intake side of the blower? Brett (from the blown section) picked up a few pounds of boost using his P600B (built 355) with a 4" solid intake and 4x12" air cleaner.
Marc
94 Z/28, 383 D-1
Old Jul 17, 2002 | 08:36 AM
9SECONDLX's Avatar
marc thanks for the info, i already did the 4 inch piping but i am using the smaller k@n filter. i will switch the filter and I bet that will help a little bit because i will get better air flow.
well if you dont go to the camaro show that is one less car i have to compete against. Just Kidding.
I think you are corect in your rpm range.
i think im going to trade my 12lb pulley with a guy who has a 15lb and im also going to have a 17lb made. then i can test them both and see where i stand. i think i can use the same belt on a 15 and 17. the 15 is 2.55 and the 17 is 2.35.
hopefully this will all be done for august 10th.
dennis
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
MadMav
Feb 6, 2015 11:02 PM
Collector Car
Dec 17, 2014 01:12 PM
