Throttle Body placement?
Old Jan 7, 2004 | 01:01 AM
mastrdrver's Avatar
Is there an optimum place to put a tb? It seems to me that between the big three, they have just about everything covered. GM does it from the front, Ford does it from the side and somewhat from the back, Dodge does it straight from the top like a carb. I would have figured that they would have had it figured out by now.
Thanks
Jeremy
Old Jan 7, 2004 | 07:13 AM
OldSStroker's Avatar
It's a combination of packaging and plenum design of the manifold. Packaging probably is the biggest factor.
For a V-engine, perhaps vertically well above the engine (so the intake runners could be straight) might be ideal, but you couldn't package it in many modern vehicles.
Although I think it looks wierd, the sidesaddle mounting of the TB on a Vortec 4200 I6 dumps the air right in the middle of the plenum. This may be more efficient than the nosemount of the Vette and F-body (as well as GTO and CTSV).
Old Jan 7, 2004 | 09:46 AM
This Dodge seems to have the TB's in the front But then, it needs to fit under a very low hood.
Old Jan 7, 2004 | 05:10 PM
mastrdrver's Avatar
After I thought about it, the front mounted tb looks to be the best. The air has to enter and atmost does a 90* turn. With the side mount the air turns 180* and with it on top the air has to turn 180* also. Just seems that it would be limiting at higher hp levels and rpms.
Old Jan 7, 2004 | 06:07 PM
LameRandomName's Avatar
I've always thought the Ford side mount TB would offer the best air distribution, although I don't have the data to confirm that.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
