How do you guys set up your manual fan switches?
Just wondering if I could install a fan switch in a LS1 car the same way I can in a OBDII LT1 car. Does this schematic work for you guys? I have put a switch in my LT1, but never in an LS1. Thanks
http://users.oco.net/xero/fanmod/
Thanks again
Thanks again
Because this is the really quick and easy way to get a manual switch by using only one relay. To get high speed you have to get creative and trigger both relays. Low speed is plenty to cool the car at the track.
i bought a homeade kit and when i turn it on it makes the SES turn on...... idk if it does it on the low speed but it does on the highspeed within seconds
Originally posted by Geezer powered
I know nobody wants to hear this but the slp kit is the easiest way to do it. Granted you can make your own for alot cheaper, but I spent the 39.99 and installed hassle free in 10mins
I did mine exactly like the link from ls1.com...
Works beautifully, altho I had them on at an autocross when it was cold out and the SES light came on once. The engine wasnt really at 210 after my run, and running the high speed fans to try and push some air over the PS setup (which will be getting a cooler soon!) tripped the light. No biggie, just discon/recon the batt and it went away.
Cost me bout 10 bucks in supplies, and I did a custom install with the switch/led's behind the ingnition switch. Dont have to look at it unless I lean, altho I have knocked the switch once and left the fans on as I walked away (they are pretty damn quiet when on low), so now Im using a stubby switch to keep from doing it again.
slothgrant
Aug 22, 2002 03:01 PM
