lt1 block cracked sleeve it ???
Old Jan 4, 2004 | 07:09 PM
BIGCOWL-IMP's Avatar
Well the crack starts at the bottom of the bore #2 cyl. and goes up about half way. if i sleeve it will it leak?? i would start over with a new block but i have splayed main caps,cleared.bored
this is a 396ci. anybody been though this ????
Old Jan 4, 2004 | 08:53 PM
OneFlyn95z28's Avatar
SOme will say yes some will say no.
might try a search for the last month or so here.
If you decide to build another block I may be interested in the one you have
Old Jan 5, 2004 | 06:21 AM
You might want to nose around on "LT1 Tech"..... there was a thread last week that asked the usual question about "wahts the biggest LT1 I can build"...... and out of the blue comes a guy who claims he is running a 4.120" x 4.00" stroke 427 LT1, using sleeved cylinders. He includes some info on how it was done.
Odd thing was, as I recall..... he was using an LT4 HOT cam in it, which must have been a little on the "mild" side
Old Jan 5, 2004 | 06:40 AM
Well I am also planning a 4.120+ bore but I aint going with a 4in stroke LOL. I will stay with my baby 3.75 stroke.
Got a link?
Old Jan 5, 2004 | 02:20 PM
Thread with guy posting about his 427ci LT1....
http://web.camaross.com/forums/showt...hreadid=208360
Old Jan 5, 2004 | 09:27 PM
Thanks Fred!
Old Jan 6, 2004 | 07:22 AM
Jason Short's Avatar
Ellis, I tried emailing you but it bounced back....
Anyway, are you resleving an LT1 block for your new build? Also, what are you doing with your old heads?
Drop me an email
jhsformula@aol.com
Thanks, Jason
Old Jan 6, 2004 | 07:47 AM
Hey Jason tey again. I just put in Correct E-mail last night. SHould Be Cybergroo@technolust.net
Old Jan 6, 2004 | 06:52 PM
got_hp?'s Avatar
im also curious about if youre sleeving............the 4.12 with 3.75 stroke is 400ci right?
Old Jan 6, 2004 | 08:10 PM
We are looking at it yes. 4.1?? Bore by 3.75 stroke
Old Jan 7, 2004 | 08:04 AM
ya i keep forgetting about the search thingy
well the blocks at the machine shop and they said they will not do it if they dont think it will seal
i will let you know what happens in a couple days
Jason the old heads are going on the 383 lt1 and its going in my other 95 imp. ss and im putting a trailor hitch on it to pull the other 396ci 95 imp ss
Old Jan 14, 2004 | 09:50 PM
well they called me and said it didn`t look good
they tryed talking me into starting over with a new block and i agreed. Well 2 minites later i called them back and ask them to take .005-010 out and take a better look so they did and guess what ???????? there was no crack it was 2 pin holes so they sleved it and hone the other cylinders and im ready to go
Chris Anderson
Jan 27, 2015 08:30 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Jessie4tin
Jan 7, 2015 08:53 AM
hotrod 5210
Dec 22, 2014 07:28 AM
squarehead
Nov 21, 2014 08:02 PM
