Going to 17X9s... from 16X8s... anything I need to do? Also what tires size?
I ahve read about different rear axle bump stops, and a different sized one for 17s, are they really needed?
Also what tire do you reccomend, I am trying to avoid wheel gap...
275/40/17 ?
275/40/17 ?
All you need to do is bolt them on. For some reason SLP put spacers under the bump stops on their cars, but I have been running without them for a long time with 17x9 and 17x11 wheels.
Changing to 17x9's is not going to close any wheel gap as the suggested tire is 275/40/17, which is the same height as the stock 245/50/16. You will need to lower the car with springs to change the wheel gap.
Originally posted by 5.0THIS
be prepared for the unsprung weight gain
cool, I know idealy they would be the same diameter just didn't want ot increase the wheel gap any...
Thanks for the help...
Dan
Taken by itself, unsprung weight is always a bad thing. Bumps upset the car more. It's why our live axle is a disadvantage.
What compensates for that is better tires, in several ways. I'll bet your car went around corners faster mostly because you got stickier tires when you changed wheel size. Some because the shorter sidewalls were stiffer. And a little because you had wider tires.
My 17x11's (24lbs) weight 4.5lbs more than my stock 16x8 wheels (19.5lbs) did. Throw a 315 Hoosier into the mix (25.5lbs) (I don't know what the stock tires weigh, but probably close to that) and I'll take the few extra pounds of unsprung weight ANY day!!!!!
Originally posted by chuck
You say that like it is a bad thing. My car has gotten faster in the turns with each increase in unspring weight (from stock 16x8 to 17x9 to 17x11).
Maybe you got faster because you went to a wider tire
But everything is a trade-off. Unless you spend an enormous amount of money to get extremely ligh wheels, you're going to see a weight increase when going to wider wheels. But that doesn't mean that the increased weight isn't offset by the much higher cornering forces. That's much like the discussion we've had up here about the weight of the 35mm front bar, yes it weighs 15lbs heavier than the stock bar, but for most of us (see how I said that Mike!
) the weight disadvantage is far offset by the much improved handling characteristics. Now I'm sure if someone made a titanium 40mm front bar for $100 we'd all be happy!!!!
what do you guys think of
Kuhmo Ecsta 712s 285/40/R17
$116 a tire...
Decent ratings...
http://www.tirerack.com/tires/tires....CSTA+Supra+712
Also I might be able to get these local usually the same price as listed on tirerack, so I woudl save $50 on shipping.
$116 a tire...
Decent ratings...
they also have the 712s in 275/40/R17
for $107
and sumitomo HTRZ II
for $119
rating is pretty good too...
http://www.tirerack.com/tires/tires....Model=HTR+Z+II
here is a comparison between the 2....
for $107
for $119
