New to car audio (amp question)
Old Dec 28, 2003 | 12:41 AM
BergerSS435's Avatar
Hey guys, I just recently bought 2 Pioneer IMPP 12's in a sealed box and was having questions about what kind of amp i need to power these? They are single voice coil, and can handle 450w peak (i'm not sure on the RMS numbers) Well anyways, i bought an 800w 2 channel Kenwood amp, and i was told after that i would need a monoblock amp, so i was going to return there (Circuit City) tomorrow and exchange for a 1000w monoblock Kenwood amp for only a few bucks more. Any help would be greatly appreciated as i have no clue if i should get a new amp, or if my 2 channel amp will make me happy. The tech at a local audio shop said that i need a mono amp because of the single voice coil speakers. Is this true?
Thanks for putting up with the newb questions,
Old Dec 28, 2003 | 06:53 AM
LS1 RULZ's Avatar
What is the impedance of your subs?
Old Dec 28, 2003 | 11:59 AM
PIONEER TS-W33C 450W 12" Subwoofer
http://store.yahoo.com/discountsonli...nts4512su.html
TSW33C
Product Features:
450 Watt Maximum Power
150 Watt RMS Power
IMPP Composite Cone
4-Layer Copper Voice Coil
4 ohms of Impedeance
Vented Pole Yoke
Freq. Response: 20-4000Hz
Sensitivity: 91dB
Sealed/Ported/Bandpass Enclosure
Recommended Enclosure: 1.5 cu ft
Old Dec 28, 2003 | 02:17 PM
LS1 RULZ's Avatar
With the amp and subs you have now you could run a stereo subwoofer system. Each sub would require it's own chamber.
If you connect the subs in parallel you'll have a 2ohm load. I doubt that your 2 channel Kenwood can handle a 2ohm load when it's bridged. In that case a class-D (or whatever the flavor of the month class) mono subwoofer amp would be ideal.
Old Dec 28, 2003 | 03:28 PM
skmoore21's Avatar
Do the Kenwood KAC801D amp. Its the mono Kenwood amp. If you are going to Circuit City, see what sales they have on the MTX's. I know that we are running some AWESOME deals in our Circuit City. Theres one MTX mono amp that is $100 off. I think its the 421D.
Steven
Old Dec 28, 2003 | 05:41 PM
Circuit City is having some major kick *** deals for amps....I was looking at the MTX amps, but ended up buying the KAC-8101D (Kenwood 1000w mono )
Old Dec 28, 2003 | 09:25 PM
firebirdude's Avatar
You'll want to wire the positives of each subwooofer together and then run it to the positive terminal on the amp. Same for the negatives. This will give you a 2 ohm load and allow you to pull the most power from your amp.
Old Dec 28, 2003 | 10:45 PM
..The amp has 2 pos. terminals, as well as 2 neg. terminals. So what you are telling me is to run both positive wires together to the same positive terminal, while doing the same with the negatives to the corresponding negative terminal?
Old Dec 29, 2003 | 06:18 AM
LS1 RULZ's Avatar
I don't know about the Kenwood but my mono MTX 6500D amp has 2 sets of outputs too. They are connected in parallel inside the amp. This is just for convenience so you don't have to piggyback the sub's connections on only one set of outputs. It must be the same for the Kenwood if it's a mono amp.
Old Dec 29, 2003 | 05:38 PM
..That's probably it, because i have two sets as well
CobraEatr
Jul 29, 2002 11:46 AM
Zomie
Jul 25, 2002 07:52 AM
Zomie
Jul 22, 2002 07:43 AM
Zomie
Jul 22, 2002 03:34 AM
gmeapush
Jul 21, 2002 07:53 PM
