Trans. and Diff. fluid recommendations....
Old Dec 17, 2003 | 11:27 PM
Allen66's Avatar
I'm about to change my rearend and transmission fluids in my '95 Formula.
What would you go with? I have the T56 transmission.
Old Jun 7, 2004 | 05:16 PM
LT1Squirrel's Avatar
bringing back to life cuz im just about to do the same
Old Jun 7, 2004 | 06:13 PM
unvc92camarors's Avatar
i'm doing the same thing with my new (used) z28
i just got sae 80w-90 gl5 gear oil plus the gm additive (#1052358) which is what is reccommended for the rear end
for the transmission, i believe i got just something dexron III or something
something dexron III will be good enough for it
i also heard i need a gasket an rtv sealant though to change the fluid? anybody know if this is true or not?
Old Jun 8, 2004 | 04:23 PM
Allen66's Avatar
I went with Castrol for the rear-end lube. Wal-Mart and our parts stores didn't have a very good selection at the time, but I knew Castrol would be a good choice.
I went with Pennzoil Dexron/Mercon for the trans, but I haven't changed it yet.
Old Jun 28, 2004 | 09:59 PM
TTT
Old Jun 29, 2004 | 02:51 PM
O-taka's Avatar
Redline D4 ATF for the M6
Redline Lightweight or Heavy Shockproof for rear
or 75W90 or 75W90NS (no limited slip modifiers) if you have a Torsen
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
