lt1 vortech guys, I need pics
Old Nov 17, 2003 | 05:42 PM
GT40MkI's Avatar
can someone take some pics of the underside of there vortech kit installed
i need to see where the filter went and and the pipeing, (around the swaybar etc)
Old Nov 17, 2003 | 07:45 PM
engineermike's Avatar
I don't have a digital camera, so I'll try to describe it.
First, mark and drill the holes for the aluminum bracket for the plastic pipe that connects to the MAF. This installs square on the driver's side frame rail. Then, install the plastic pipe and the aluminum bracket with the four supplied screws. There are two small ridges on the pipe that will indicate where it goes in the bracket. For reference, the MAF end should angle slightly towards the front of the car.
Then, install the elbow on the supercharger and point it almost straight down. You'll have to angle it slightly to get the best clearance.
Install the sway bar.
Install the dryer ducting. It should run from the supercharger 90, under the sway bar (closer to the ground), then connect to the MAF plastic tube.
Hope this helps.
Mike
Old Nov 17, 2003 | 09:59 PM
GT40MkI's Avatar
Hope this helps.
Mike
thank you it does help
anyone with pics ?
Old Nov 18, 2003 | 02:24 AM
GT40MkI's Avatar
how can i move the maf to the discharge?
the tubeing is 2 long
Old Nov 18, 2003 | 06:43 AM
96 WS6's Avatar
You have to cut the intake elbow down, I cut the plastic tube a little bit and about an inch and a half off the intake elbow to make it fit. I will get pics tomorow when I can.
Old Nov 18, 2003 | 08:55 AM
[JFS]'s Avatar
BAM !!!
Old Nov 18, 2003 | 01:29 PM
TimChiaretto's Avatar
As 96WS6 said you have to cut down the elbow to fit the MAF on the pressure side. If you have the Vortech cooler then you have to go a bit further. Take a look at my site. It has a number of shots of the intake tubing I made from the blower to the intercooler and to the inlet.
Old Nov 19, 2003 | 04:42 PM
bowtiepwr's Avatar
Originally posted by [JFS]
BAM !!!
>What size cog setup is that and how much boost are you seeing ?
Old Nov 22, 2003 | 02:54 PM
bowtiepwr's Avatar
>So where are the pictures ?
onefastgta
Mar 19, 2015 10:10 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
GhostZ28
Dec 7, 2014 11:53 PM
Red97LT1
Aug 7, 2002 05:45 PM
