nos opener, what kind of switch
Old Nov 11, 2003 | 09:40 PM
slow's Avatar
what kind of switch is needed for a nos opener?
spdt momentary? is what i have heard, is that correct?
anybody have the installation instructions Ryan212@aol.com if you do, thanks
thanks
Ryan.
Old Nov 16, 2003 | 11:54 AM
slow's Avatar
wow... nobody has a NOS brand opener?
I need some help, i have only run NX products, and they use a DPDT momentary... but im hnow sure on this nos one.
Ryan
Old Nov 16, 2003 | 11:00 PM
The switch that is supplied with the NOS bottle opener is a momentary double-pole/double throw. But you don't need a double-pole, only a single pole. It has to be a 12V/25-amp switch because it wires directly to the opener solenoid, and not to a relay.
If you post or e-mail a fax #, I will fax you the NOS instruction sheet.
Old Nov 17, 2003 | 08:34 PM
slow's Avatar
thank you.
Ryan212@aol.com is the e-mail.
wow... 25 amps... thats a lot of juice, i guess the 18 gauge wire i was going to use is too small for that..
Ryan.
Old Nov 17, 2003 | 09:48 PM
I meant for you to post your fax number here, or e-mail me your fax number.
You definitely need more than 18-ga wire. It might not actually draw 25-amps, but you need a switch rated that high, not the typical 6-amp or 10-amp rated switch.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Heathen1
Jan 2, 2016 04:27 PM
May 21, 2015 01:04 PM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
