driver side door component speaker sounds like...crap
Old Nov 8, 2003 | 11:26 PM
ronin013's Avatar
i have an aftermarket component set in the front doors, its an alpine set i forget which they were cheap but maybe now i see my mistake. it just sounds like there is a lot of background noise or static, like a "fuzzy" sound. even if i mute the radio its still there i want to punch the thing and make it stop. connections are all tight, although there is a little rust on the screws holding the wires on this plastic box deal i cant remember what is called. is there anything i can do or check, or do i have to replace the damn things?
Old Nov 8, 2003 | 11:46 PM
firebirdude's Avatar
Sounds like you are picking up some induced noise. Are the speaker running off an aftermarket amp? I bet a good solid re-grounding job would help.
Old Nov 9, 2003 | 08:57 PM
ronin013's Avatar
well i have a 4 channel amp, i cant remember which sets are running off of it, but i think it might be front and rear and i left the middles alone i cant remember that far back. how could i re-ground it? im not too good with this audio stuff, im better under the hood
Old Nov 10, 2003 | 12:16 AM
cheezer's Avatar
make sure your ground has a solid metal connection scrape away all paint ect. also make sure you have your powerwire and rca cables running on the oppsite sides of your car thats another way to pick up pink noise
Old Nov 10, 2003 | 11:16 AM
ronin013's Avatar
where do i run the ground off of though? the amp? the speaker? running a ground to part of the frame i understand, i just dont know where to connect the other end
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
yosshimura
Aug 12, 2002 06:47 AM
