800-700rpms normal???
Old Nov 8, 2003 | 06:36 PM
Jaswir's Avatar
Car in sig, well it use to idle all the time at about 1100 and 1200 but now its droped? how could i change the idle???
Old Nov 8, 2003 | 07:05 PM
nothingeined's Avatar
Is it stumbling or anything? My car car idles at 700-800 and it is running fine. My 93 used to idle at about 1100-1300 and that was cause it had a couple of problems. Did you add or remove anything before you experienced this?
Old Nov 9, 2003 | 01:42 PM
Jaswir's Avatar
some time it stubals when i slow down at a light... umm it broke down about 3 weeks ago the ignition modulator went out, nothing major but it seem after i put the new one in lower rpms and take offs from a stop. plus when i first start it and in Netural it idels at 1100 to 1300 but i think it use to idle at 1,000 to 1,100 all the time
Old Nov 10, 2003 | 03:09 PM
kevin 2.8's Avatar
my 2.8 with 100,000 kilometers, (70,000 miles) idles at 600-700 rpm after its warmed up if its cold it starts at 1,100 then drops.
it runs fine.
it shouldnt stumble at this rpm range, you may want to do a tuneup
Old Nov 10, 2003 | 11:59 PM
camaro6's Avatar
On my 92' I had a long time ago, it idled around 700 - 800. I think thats pretty much normal for most cars. However my 94' is having some problems with its idle
Old Nov 12, 2003 | 02:14 AM
oil pan 4's Avatar
Lightbulb
Chilton's manual says
'' 1988, 2.8L, ignition timeing 10* before TDC, 700rpm idel for auto and std. trans."
Thats for when it's all the way warmed up.
So your idel is high.
Old Nov 13, 2003 | 09:07 AM
deadmeat2004's Avatar
mine is idliing around 1000 1100, someone above said thiers did that but it had a few problems, what were they and how do u fix them?
Old Nov 13, 2003 | 12:03 PM
mako350Z28's Avatar
I had a 91 RS 3.1 several years ago, but if I remember correctly it idled at 700-800 RPM. So no need to worry.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SEOJustin
Sep 24, 2015 04:39 PM
plattted
9
Sep 20, 2015 11:23 AM
